Η AOC είναι γνωστή εταιρεία στην Αμερική για τις value Οθόνες της.
Για την συγκεκριμένη η τιμή που ανακοινώθηκε στα $350.
Ελλάδα οι τιμές αναλόγως το μοντέλο ποικίλουν.
Ωραίο χαρακτηριστικό σε αυτό το μοντέλο οτι είναι borderless.
Φoβερό για όσους ασχολουνται με sound ή video editing, music production
αλλά και φανατικούς gamers όπου τα πολλαπλά monitors είναι απαραίτητα.
Press Release:
AOC Announces Borderless 27" IPS Monitor; Now Available at Retailers Nationwide
AOC's ultra-slim i2757fh HD monitor features a borderless appearance ideal for multiple monitor setups
Fremont, Calif. – October 2, 2012 – AOC, the leader in monitor display technology, announces the retail availability of the i2757fh, a 27-inch IPS display with a 2 mm bezel that gives the monitor a sleek, borderless appearance. The monitor's widescreen IPS (in plane switching) panel also allows for more consistent, uniform color from all viewing angles, delivering amazingly sharp image quality. An iF Product Design Award winner, the monitor delivers uncompromising display technology coupled with an artistic design that features a metallic hook-shaped stand that allows for three different modes of viewing – as a photo frame without a base, as a standard function stand, and as a height-adjustable stand that detaches with the push of a button. The AOC 27-inch IPS Monitor is now available for $349 MSRP. AOC also offers the i2757fh at Bestbuy.com and the retailer's top 250 stores for a special price of $299.99.
"The i2757fh model, part of AOC's 57 Series, combines an anti-glare IPS screen with a narrow bezel so that images seem to float without a distracting frame," said Chris Brown, AOC Marketing Manager. "The monitor's IPS technology and award-winning design deliver an unparalleled display experience to consumers."
Designed to meet high environmental and technical standards, the i2757fh is made of eco-friendly materials such as arsenic-free glass and mercury-free panels. Also, the LED backlight panel requires 50 percent less energy than typical CCFL monitors. The i2757fh can display 16.7 million colors, while its 50,000,000:1 Dynamic Contrast Ratio provides accurate color reproduction when displaying images with extreme differences between light and dark. The monitor also features ultrafast performance with a 5 ms response time, which allows pixels to change colors quickly to avoid streaking, blurring and ghosting in fast-moving scenes and video games. The monitor's dual HDMI ports support the latest DVD and Blu-ray players or gaming consoles, and it can also be connected to desktops or notebooks via VGA cable. Direct insert connectors face the rear, making it easier to connect the monitor to power and input sources.
The monitor also includes built-in speakers for optimal desktop sound, and the multifunctional, detachable stand allowing for standard monitor or "photo frame" placement. Other bonus features include an Off Timer that shuts down the monitor automatically if desired, Screen+ software that divides the screen into four self-contained work areas for improved productivity, and Eco Mode, which enables the user to select five different optimized display settings (Text, Internet, Game, Movie and Sport).
HighLights:
• Ultra-thin LED IPS Monitor (10.6mm thin)
• Multiple I/O Ports (2 HDMI)
• Viewable Image Size: 27”
• 16:9 Aspect Ratio
• WLED Backlight
• Brightness: 250cd/m2
• 50,000,000:1 DCR
• 5ms Response Time
• Two built-in speakers
• Screen+ Technology
• e-Saver Feature for low power consumption
• 16 OSD languages including English, Spanish, French and more
• iF Design Award winner
Βασικά χαρακτηριστικά:
[TABLE="width: 500"]
[TR]
[TD]Ίντσες[/TD]
[TD]27"(16:9)[/TD]
[/TR]
[TR]
[TD]Brightness[/TD]
[TD]250 cd/m[SUP]2[/SUP][/TD]
[/TR]
[TR]
[TD]Contrast[/TD]
[TD]50000000:1[/TD]
[/TR]
[TR]
[TD]Response Time[/TD]
[TD]5ms[/TD]
[/TR]
[TR]
[TD]Ανάλυση[/TD]
[TD]1920 x 1080 @ 60Hz[/TD]
[/TR]
[TR]
[TD]Χρώματα[/TD]
[TD]> 16 Million[/TD]
[/TR]
[TR]
[TD]Analog Input[/TD]
[TD]RGB D-Sub[/TD]
[/TR]
[TR]
[TD]Digital Input[/TD]
[TD]HDMI with HDCP[/TD]
[/TR]
[TR]
[TD]Ηχεία[/TD]
[TD]4W[/TD]
[/TR]
[TR]
[TD]ENERGY STAR � Compliant[/TD]
[TD]Nαι[/TD]
[/TR]
[TR]
[TD]EPEAT Rated[/TD]
[TD]Ναι[/TD]
[/TR]
[/TABLE]
Download: Spec Sheet | Manual | Φωτογραφίες
Πηγή
