- 5 December 2006
- 8,069
MASK 6 MΑΥΡΟ ΧΡΩΜΑ
http://www.musik-service.de/apart-audio-mask-bl-prx395760054en.aspx
Type : 2-way HiFi Pro, sealed box
Cabinet : Enforced PP4 ABS
Woofer : 6.5” HD Type
Tweeter : 1” HD silk dome on Varithroat horn
Impedance : 8 Ohm
RMS Power 8 ohm
AES Rated : 150 watt
Music - Program : 200 watt
Dynamic Peak (low-cut) : 400 watt
Protection : Auto-Reset 3-step Protection Guard
SPL 1 watt/1M : 92 dB
SPL Max peak : 121 dB
Freq. range : 65 Hz - 20 kHz
Dispersion : Push terminals
5° downtilt angle / 120° H x 80° V
IP rating : 64
Thread size mounting point : M12
ΔΕΝ ΕΧΟΥΝ ΠΑΙΞΕΙ ΣΧΕΔΟΝ ΚΑΘΟΛΟΥ...ΧΩΡΙΣ ΕΓΓΥΗΣΗ..
100 e το ζευγαρι με τα μεταφορικα (ελτα)
Impedance : 8 Ohm
RMS Power 8 ohm
IP rating : 64
