Aragon Stage One
tsoulfas panagiotis
28 August 2006
1,046
ενας απο τους καλυτερους processors,πριν καποια χρονια.Ειναι THX ULTRA2 κ εχει 7.1 αναλογικες εξοδους k 24-bit/192kHz σε ολα τα καναλια
Description : 8-ch THX Ultra2 Surround Preamplifier
FREQUENCY RESPONSE: 10Hz-100kHz +0/-3dB
DIRECT INPUTS FREQUENCY RESPONSE: 10Hz-20kHz +0/-0.2dB
ANALOG INPUTS FREQUENCY RESPONSE: 20Hz-20kHz +0/-0.5dB
DIGITAL INPUTS FREQUENCY RESPONSE: 20Hz-20kHz +0/-0.5dB
THD: <0.02% (20Hz-20kHz)
S/N RATIO: 108dB (Direct Inputs)
MAXIMUM OUTPUT: 7V rms
DSP ENGINE: Motorola 56367
Insulated Speaker Binding Post Terminals (2 sets per channel)
D/A CONVERTERS:
Crystal 24-bit/192kHz - all 8 channels
ANALOG AUDIO INPUTS:
7 Pair Left/Right Gold-plated RCA Phono Jacks
DIGITAL AUDIO INPUTS:
7 Coaxial, 3 Toslink Optical
VIDEO INPUTS: 7 Composite, 7 S-video, 3 Component Video (HD Compatible)
MULTICHAQNNEL EXTERNAL AUDIO INPUTS: 8-ch via DB-25
ANALOG PREOUTS: 8 Gold-plated RCA Phono Jacks
RECORD/TAPE LOOP OUTPUTS: 2 Pair Left/Right Gold-plated RCA Phono Jacks
DIGITAL AUDIO OUTPUTS: 1 Toslink Optical
VIDEO OUTPUTS: 2 Composite, 2 S-video, 1 Component Video (HD Compatible)
COMMUNICATION AND CONTROL: RS-232, 12VDC Trigger Out, IR Input
REMOTE CONTROL: Philips ProntoNEO Touchpanel Learning
POWER CONSUMPTION: 40W
DEMENSIONS: HEIGHT: 5.8" (14.7cm) WIDTH: 17" (43.2cm) DEPTH: 15.25" (38.7cm)
WEIGHT: 27 lbs. (12.3kg)
