Asus Wireless PCI Adapter Super Speed N WL-130N αχρησημοποιητη με υπολοιπο εγγυησης , πωλειται 45 ευρω δηλαδη 35 % κατω απο την σημερινη τιμη της στο πλαισιο. 6937306752
Specifications
Specifications
Host interface
PCI 2.3
Solution
Ralink
Operating Frequency
2.4 - 2.5 GHz
Data Rate
802.11n Draft: up to 300Mbps*(*Note: The maximum wireless signal rate is IEEE802.11n draft specifications. Actual throughput will vary depending on the wireless environment and other parameters)
802.11g: 6, 9, 12, 18, 24, 36, 48, 54Mbps
802.11b: 1, 2, 5.5, 11Mbps
Modulation
DSSS, OFDM
Network Architecture Types
Infrastructure and ad-hoc
Operating Modes
11 for N. America, 14 Japan, 13 Europe (ETSI)
RF Output Power
12~14dBm(g mode), 14~16dBm(b mode), 14~16dBm(n mode)
Antenna
External extension antenna
Receiver Sensitity
-66~-68dBm @270Mbps
-74~-75dBm @54Mbps
-87~-88dBm @11Mbps (at normal temp. range)
-95~-97dBm @ 1Mbps
DC Power Adapter
TX power consumption: 850 mA
RX power consumption 600 mA
Encryption
64/128-bit WEP, WPA, WPA2, TKIP, AES, WPA-PSK, WPA2-PSK, 802.1x
PCI 2.3
Solution
Ralink
Operating Frequency
2.4 - 2.5 GHz
Data Rate
Modulation
DSSS, OFDM
Operating Modes
RF Output Power
Antenna
Receiver Sensitity
-66~-68dBm @270Mbps
-74~-75dBm @54Mbps
-95~-97dBm @ 1Mbps
DC Power Adapter
Encryption
