Audia Flight 3
Λάκης
26 September 2007
14,357
Είμαι παντού
Πωλείται ο εν λόγω ενισχυτής,σε πολύ καλή κατάσταση.
http://audioevolution.gr/reviews_focus.asp?id=36&page=4
Technical Data
Output power Wrms 8 / 4 ohm 75W / 125
Amplifier stage gain 26dB
At maximum volume:
Frequency response (1Wrsm, -3db)
1Hz - 450KHz
Slew Rate (on 8 ohm) >80V/ΒϴS
THD <0,05%
S/N ratio >95dB
Unbalanced input impedance 51Kohm, 150pF
Balanced input impedance 30Kohm
Stand-by consumption less than 1W
Maximum consumption 400W
Dimensions and weight 420x90x420 (W x H x D), 12Kg
Shipping dimensions and weight 530x240x530 (W x H x D), 15Kg,INPUTS and OUTPUTS:4 unbalanced input,1 balance input,1 monitor input,a possibility to have one input as a β€œdirect,1 pre output,1 rec output,1 output for headphone
Εχει home cinema passthrough για οποιον θελει να το χρησιμοποιησει και σε home cinema
Τιμη 1300 .
