Audia flight two
Status
Not open for further replies.
achilleas8095
26 June 2006
434
2
Πωλείται ο εκπληκτικός Ιταλικός ολοκληρωμένος
Audia Flight Two
The Audia Flight Two integrated amplifier is a combination of Audia Flight’s superb design of the preamp and power amplifier in one chassis. The Audia Flight Two offers all of the sonic benefits of the Audia Flight separates in one space saving cabinet with an optimal internal interface and a reduced need for interconnects. Two 100Wrms high bias amplifiers with 520VA toroidal transformer, dual mono design, the current feedback and preamp section employs an input buffer for a stunning sonic picture and a truly high-end system.
Technical Data
Output power W rms 8/4 ohm 100/180 (τα πρώτα 12 watt σε τάξη Α)
Amplifier stage gain 26 dB
Frequency response (1W rms -3dB) 3 Hz ÷ 500 KHz
Slew-Rate (on 8 ohm) > 180 V/μS
THD < 0,05 %
S/N Ratio 95 dB
Input impedance 680pF Unbalanced 51 Kohm
Balanced 23 Kohm
Main voltage AC (50-60Hz) 100, 110-115, 220-230, 240 V
Power consumption 100 W, 570 W MAX
Dimensions and weigth 420x113x440mm (wxhxd) - 19 Kg
Shipping dimensions and weigth 570x270x540mm (wxhxd) - 22 Kg
Links
http://www.audia.it/products_new.php?codpro=7
Review
http://www.soundstagehifi.com/index.php?option=com_content&view=article&id=175:audia
Τιμή 1700 ευρώ (τιμη καινούργιου 3700)
Επίσης ανταλάσετε με ολοκληρωμένο με δυνατότητα home theater passthrough με απαραίτητα XLR εισόδους
Status
