av-SONY STR-DB1070
Status
Not open for further replies.
kernel panic
18 November 2008
967
Κεφαλλονιά
Sony's ultra-popular "DB" series receivers borrow technology and design from their high-end "ES" line, to deliver a truly superb sonic experience! Just check out the STR-DB1070. It drives 100 full-bandwidth-rated watts x 6 channels of power, utilizing "master in-line" configuration for even performance across all channels. Add in 6.1-channel inputs and outputs, and pristine 6.1-channel processing, and you're more than equipped for today's and tomorrow's cutting-edge home theater and music sources.
For precise, natural sound, dual 32-bit processors handle the surround decoding (Dolby® Digital, DTS®, 6.1, Dolby Pro Logic™), Virtual Matrix 6.1, and Digital Cinema Sound™ modes. Feed digital audio to the 'DB1070's 192kHz/24-bit D/A converters, or bypass all DSP via "analog direct" — great for high-resolution multichannel or stereo sources like SACD. Your video's in good hands, too, thanks to composite, S-video, and component video inputs and switching.
To its core, the 'DB1070 is on a sound quality mission. Premium frame-and-beam construction and an aluminum front panel ward off vibrations that can distort your music. Short signal paths minimize signal loss within the unit. To maximize clarity, Sony's OP (Optimum Pre-Amplification) Processing ensures a high signal-to-noise ratio at all volume levels. An Analog Pureness Control even cuts the power supply to the digital and video sections when they're not in use, to further eliminate noise.
Details:
  • full-bandwidth-rated power: 100 watts x 6 into 8 ohms (20-20,000 Hz) at 0.09% THD
  • dual 32-bit processors for surround decoding (Dolby Digital, DTS, 6.1, Dolby Pro Logic), Virtual Matrix 6.1, and Digital Cinema Sound modes
  • 192kHz/24-bit DACs
  • Optimum Pre-Amplification Processing
  • Analog Pureness Control
  • component video switching: 2 in, 1 out (50MHz bandwidth)
  • 6.1-channel and 5.1-channel inputs
  • 6.1-channel preamp outputs
  • stereo and multichannel "analog direct" mode
  • learning/multibrand remote with macro capability
  • on-screen Graphical User Interface (direct video input required on TV)
  • 4 digital inputs (3 optical, 1 coaxial)
  • optical digital output
  • 4 audio (including phono) and 5 A/V (including 1 A/V behind the flip-down front panel, and 4 S-video) inputs
  • 1 set main speaker outputs
  • dual-room/dual-source output
  • binding posts for all speakers
  • frame-and-beam construction
  • aluminum front panel
  • large filter capacitors, power supply and output transistors
  • short signal paths
  • 30 AM/FM presets
  • Control A1ii and S
  • 17"W x 6-3/8"H x 16-1/2"D
We have decided to sell this item as we are currently replacing all our stereo equipment with BOSE....it originally cost us $1300.00, been used for about 3 years and has been an excellent receiver!
Where Is As Is Recommend adding full insurance on all electrical components.
μέτρια κατάσταση εμφανισιακά,
τιμή 130,00
όχι καθόλου είναι άριστο εμφανισιακά
κόπηκε ο ρυθμιστής ήχου και έχει μπει με πατέντα
επίσης το χειριστήριο του λειτουργεί με πολλές άλλες συσκευές (tv,dvd,cd-player κτλ)
θα ανεβάσω και φώτο.
Status
