Azbox: servers with plugins and addons
AlexT_
10,458
Τροποποιήστε με κάποιον editor τα δύο αρχεία ως εξής:
Here is the way to edit the plugins and addons server configuration files.
It is only possible to set 4 servers so choose the one you prefer yourself, the one below are just sample files.
In the /EMU folder create or edit a file called plugins.conf:
/EMU/plugins.conf
Code:
[SERVER]
PLUGINS_SERVER_1=http://www.descargas.azboxhd.es
PLUGINS_SERVER_2=http://www.islaremota.com/azp
PLUGINS_SERVER_3=http://www.satelites.info/azbox/
PLUGINS_SERVER_4=http://www.azupd.com
# Only 4 servers possible
# PLUGINS_SERVER_x=http://azboxhd.no-ip.org
# PLUGINS_SERVER_x=http://azboxworld.com
In the /EMU/OpenXCAS folder edit a file called addons.conf:
/EMU/OpenXCAS/addons.conf
Code:
[SERVER]
[SERVER]
CAMD_SERVER_1=http://www.islaremota.com/aza
CAMD_SERVER_2=http://www.satelites.info/azbox/
CAMD_SERVER_3=http://www.descargas.azboxhd.es
CAMD_SERVER_4=http://azboxworld.com
AUTO_MY_SERVER=http://azboxworld.com
# Only 4 Add-ons server possible
# CAMD_SERVER_x=http://azboxhd.no-ip.org
No need to reboot the Azbox, simply exit the Plug-ins menu and re-enter it, change in the files will be taken into account.
Προσθέστε τις γραμμές που είναι με bold.
Διατίθενται για κατέβασμα τα εξής:
Plugins:
* OpenXCAS
* OpenXCAS2
* OneStep_EMU
* MultiCAS
* IncubusCamD
* gCam
* LiveScores
* SudoQ
* TuxChess
* WeatherForecast
Addons:
* MultiCAS_v157D-4T11-2_2k90613.tar.gz
* MultiCAS_v157D-4T10.tgz
* MultiCAS_v157D-4T7_2k90514.tgz
* MultiCAS_v157C_2k90325.tgz
* NewCS_Full.tgz
* CCcam_v0.3b_FULL.tgz
* CCcam_v0.3b_UPD.tgz
* CCcam_v0.1b_FULL.tgz
* CCcam_v0.1b_UPD.tgz
* IncubusCamd_v0.55.tgz
* Mbox_v0.5b_build.v0024_FULL.tgz
* Mbox_v0.5b_build.v0024_UPD.tgz
* Mbox_v0.4b_build.v0023_FULL.tgz
* Mbox_v0.4b_build.v0023_UPD.tgz
* NewCS_IncubusCamd.tgz
* NewCS_IncubusCamd_Mbox.tgz
* NewCS_Mbox.tgz
* MGCamD_Full.tgz
Αρχιζουν να περνουν τα πανω του σιγα σιγα τα αδελφια AZ!
Και cccam βλεπω μεσα!
