Πωλουνται monitor Behringer MS40
Πωλείται και η κάρτα Creative Audigy 2 NX, με όλα τα παρελκόμενα της σε άριστη κατάσταση.
Τηλ. 6944885539
24-Bit/192 kHz Digital 20-Watt Stereo Near Field Monitors
2-way active studio monitors ideally suited for computer studios, audio and multimedia workstations and
keyboard monitoring
Built-in 2 x 20-Watt powerful amplifiers with immense headroom
Powerful woofers and high-resolution tweeters provide an ultra-linear frequency response
Ultra-high resolution 24-bit/192 kHz D/A converters for an incredible dynamic range
Optical and coaxial inputs accept virtually any kind of digital audio format
Two stereo analog inputs featuring 1/8" TRS and stereo RCA connectors can be used simultaneously or
mixed with a digital stereo source
Individual volume controls for both Line inputs plus Bass and Treble EQ controls
¼" TRS headphone connector with auto-mute loudspeaker function easily accessible on the front panel
Magnetically shielded for placement near computer monitors
High-quality components and exceptionally rugged construction ensure long life
Conceived and designed by BEHRINGER Germany
Χαρακτηριστικά:
Signal to Noise Ratio:
Front/Rear/Center/Sub 102dB @ 2Vrms
Headphone/Side 96dB @ 2Vrms
24-bit/96kHz Analog-to-Digital Converter (ADC) for various analog inputs
24-bit/96kHz Digital-to-Analog Converter (DAC) for up to 7.1 channels output
Supports Sony/Philips Digital Interface (S/PDIF) format input signal of up to 24-bit/96kHz quality
Recording/Playback: up to 24-bit/96kHz (requires USB 2.0 port and Windows XP)
SoundFont 2.1 Support for Midi playback
Περιλαμβάνονται:
Sound Blaster Audigy 2 NX
Infra-Red Remote Control
AC Power Adapter
Four 3.5mm Stereo Cables
USB Cable
Quick Start Leaflet
User's Guide On CD
Feature Showcase Demonstration CD
Creative DVD-Audio Sampler Disc
Creative Software Pack On CD including: Creative MediaSource (v.2), Creative Device Control, Creative Speaker Settings, Creative EAX Console, Creative Graphic Equalizer, Creative Surround Mixer, Creative WaveStudio, Creative MiniDisc Center, Creative SoundFont Manager And Creative Diagnostics
AC Power Adapter
USB Cable
Quick Start Leaflet
User's Guide On CD
Ανεξαρτητη τροφοδοσια ρευματος
Τηλ. 6944885539
