BenQ W30000 LED 1080p Projector!
takisot
Μέλος Δ.Σ.
29,250
Παλλήνη
Ρε λετε?!
W30000 LED Home Cinema 1080p Projector
Targeting high-end home cinema, the W30000 combines Full HD 1080p sophisticated cinema performance with the unparalleled advantages of progressive LED technology. Among the world's first to launch an LED projector lineup that includes luxury home cinema, BenQ raises theater ‛wow' to a new level of immersion: an unrivaled 128% NTSC color gamut (compared to the average 55%-80% NTSC of most projectors) complemented by an extreme 100,000:1 contrast ratio underlies exquisite picture quality and razor-sharp definition. LED-produced images are bolder and more deeply saturated across a broader color gamut, which means the W30000 is able to generate vastly more distinct colors, with each color being extraordinarily richer and more vibrant than conventional projectors. LED also affords 20,000 hours of projection lighting; coupled with BenQ's filter-free DLP design for flawless, never-fade color accuracy, the W30000 provides a near lifetime of enjoyment. Cinematic quality is further supported by BrilliantColor®, DynamicBlack®, 600AL, and Hollywood Quality Video (HQV®). Using Imaging Science Foundation™ calibration standards (ISFccc), each W30000 can be fine-tuned to its unique environment to ensure optimal video performance of various preset applications. Panamorph Lens compatibility further lets users fully duplicate the theater experience with a true widescreen 2.35:1 aspect ratio.
http://www.dcviews.com/press/benq-w30000.htm
Χμμμμμ, καλό ακούγεται.... για να δούμε πότε θα το δούμε και τι στ´αλήθεια θα δούμε!
Δημήτρηηηηηη (Δημητρακόπουλε) άρχισαν τα όργανα???
Φιλικά
Γιώργος.
Αυτό το 100000:1 και το 128% colour gamut μου φαίνονται λίγο extreme.
Πάντως η BenQ γενικώς είναι αξιόλογη στους προβολείς της και δεν "μεγαλοποιεί" τους αριθμούς...
Απάντηση: Re: BenQ W30000 LED 1080p Projector!
Φιλικά
Γιώργος.
Ναι ρε Δημητρακοπουλε, που εισαι; :p
Λεω να ρωτησουμε τον Σωτηρουδη! :D
Γιωργη, λες να ειναι το επομενο προβολακι σου;:guitarist:
Μεταφέρω την επίσημη θέση της (μισής τουλάχιστον) διαχείρησης της κατηγορίας:
Δεν καταλαβαίνω γιατί ασχολείστε.
Το άρθρο είναι προφανώς αναξιόπιστο (εφ)άπαξ (που έλεγε και ένας φίλος :p) και αναφέρει: ''W6000, successor to the W5000''
:p
Edit
ΔημητραΚούλης rulez :p
Re: Απάντηση: Re: BenQ W30000 LED 1080p Projector!
Άσε την έκανα! Τρία πουλάκια κάθονταν..... :BDGBGDB55:
Δημήτρη sorry, apologize for my crime (άκου Δημητρακόπουλος!!!), αλλά τι περιμένεις στις 2 τα ξημερώματα -bye-
Κάτσε βρε φίλε πρώτα να τον δούμε, ακόμα δεν τον είδαμε Γιάννη τον βγάλαμε!
Αλλά όταν θα έρθει εκείνη η ώρα σίγουρα θα ρωτήσουμε τον κ. Σωτηρουδη!, όπως πολύ σωστά προτρέπεις παραπάνω :flipout:
Φιλικά
Γιώργος.
Εγώ περιμένω να δώ τι θα μας πεί κι ο Δημήτρης... Μην μας βγεί κι αυτός Data και την πατήσουμε... :flipout: :flipout:
Πάντως το 100,000:1 δεν το βρίσκω και απίθανο, αφού ως γνωστόν όταν σβήσει το led τελείως π.χ. 0 IRE, τότε φυσικά και μιλάμε για το απόλυτο μαύρο, σαν να είναι κλειστό το μηχάνημα.
Και στα δικά μας αν μετρήσουμε το μαύρο με κλειστό το μηχάνημα και το λευκό , κάπου εκεί θα βγει το contrast.
Παίζει καμιά ημερομηνία;
Re: Απάντηση: BenQ W30000 LED 1080p Projector!
Χμμμμ.... Δεν αναφέρουν καν ANSI lumens.. Άρα είναι σίγουρα Home Cinema.. :p
O W6000 από την άλλη..... :flipout:
Άντε μπάς και δείτε λίγο πραγματικό μαύρο, και σας φύγει λίγο άγχος, από το να κοιτάτε το ρολόι σε κάθε ταινία!!! :flipout:
