best sound Montreal 2010 dCS+Verity...
Γιώργος ΚΟΨ
20 June 2006
3,323
GLYFADA
πριν 2 εβδομάδες τέλειωσε το audio show [festival du son] Montreal 2010
για άλλη μια φορά η dCS με τη Verity πρωταγωνίστησαν....
DCS + VERITY:ernaehrung004:
AUDIO FESTIVAL IN MONTREAL end March 2010
The Son or Filtronique room had a lot of conversations going on, but it was evident this was one of the Best Rooms at the show. The system here had a dCs digital front end feeding Audio Research preamp and monoblocks that powered the Verity Audio speakers. This room adds to the buzz that Audio Research is coming back very strong after subsisting in the shadows for some years. dCS and Verity have been there all along. The finish on the Verity was both subtle and rich with a vague blue-ish stain on Birdseye maple veneer that really came to life in the flash photo. I suggest you put a couple of small spotlights on these in your listening room when entertaining to show them off at night.
http://www.enjoythemusic.com/salon_son_image_2010/part2/page2.htm
Verity Audio Amadis speakers ($30K) with a rear firing woofer sounded very good, as do all Verity speakers. This was the world premier for this model, third from the top of their line. With 93dB efficiency they were easily driven here by Nagra VPA monoblocks with 845 tubes that were sitting on maple butcher block stands. The shape of Verity speakers has practically become their corporate signature, differing primarily in size and drivers from one model to the next. The size of the Amadis belied the large room filling music they were putting out and the large audience listened in rapt attention. A dCS digital front end looked to be the source, as it usually is in the Verity room, helping to earn mention as one of the Best Rooms at the show. This room is not to be confused with the Son or Filtronique room heard earlier which also featured Verity speakers with a dCS front end and also garnered Best Rooms recognition. Do you detect a pattern here?
http://www.enjoythemusic.com/salon_son_image_2010/part3/
είπα και εγώ λέει καλή κουβέντα ο geopolitis γιά άλλο σύστημα αλλά μετά πρόσεξα τα ηχεία.... :smash:
αμεσως εσυ...
αντε να κανουμε zoom τοτε
file.php
εγω παντως ψαρωσα με τα reviews γιατι το συστημα αυτο επαιζε χωρις προενισχυτη!!!
Ψιλοάσχετο, στο δεύτερο link η δεύτερη φωτογραφία με τα ηχεία Joseph Audio Pulsar, δεν σας φέρνει κάτι από Audio Spectrum Electra?
Μικρό ηχείο με τα καλά μεγάφωνα της seas είναι...Κυκλοφορούσαν(και πρίν την Ηλέκτρα) και κυκλοφορούν πάμπολλα παρόμοια μ' αυτά τα μεγάφωνα.
Πλάκα έχει η διαφοροποίηση των τιμών,για τόσο κοντινά σε κατασκευή ηχεία...Απο ~1000+ μέχρι κοντά στις 10000....
