Blackmagic Studio Camera 4K / Pro
evanfotis
26 March 2008
5,884
Camera Features​
Effective Sensor Size​
17.78mm x 10mm (Four Thirds)
Lens Mount​
Active MFT Mount.
Lens Control​
Iris, focus, zoom on supported lenses.
Dynamic Range​
13 Stops.
Dual Native ISO​
0dB and 18dB gain.
Sensitivity at 0dB Gain​
f11 with 2160p59.94.
f12 with 2160p50.
at 2,000 lux with 89.9% reflectance.
Signal to Noise Ratio​
63dB for 2160p.
Shooting Resolutions​
3840 x 2160 (Ultra HD) up to 60 fps.
Frame Rates​
23.98, 24, 25, 29.97, 30, 50, 59.94 and 60 frames per second.
Off-speed frame rates up to 60 fps in Ultra HD.
Focus​
Auto focus available using compatible lenses.
Screen Dimensions​
7 inch 1920 x 1200
Screen Type​
LCD capacitive touchscreen.
Screen Brightness​
2000 nits
Controls​
Touchscreen camera settings and menus with rotary settings dial, program button, F1, F2 and F3 assignable function buttons, brightness contrast and peaking dials.
Mounting Options​
2 x 1/4 inch tripod mount.
1 x 3/8 inch tripod mount.
Connections​
SDI Video Inputs​
1
SDI Video Outputs​
1
SDI Rates​
1.5G, 3G, 6G, 12G.
HDMI 2.0 Video Outputs​
1
Analog Audio Input​
2 x XLR analog switchable between mic and line levels. Phantom power support.
1 x 3.5mm Stereo Input. Can also be used for Timecode input.
Analog Audio Output​
1 x 5-pin XLR for talkback headset.
1 x 3.5mm TRRS mini jack for headphones with mic.
Reference Inputs​
Tri-Sync or Black Burst when used with optional Blackmagic Studio Converter.
SDI Audio Output​
2 channels of program audio embedded in 1.5G/3G/6G/12G-SDI. 2 talkback channels on 15 and 16
Remote Control​
Remote camera control over SDI, HDMI or Ethernet.
Ethernet​
10Gb/s
Computer Interface​
2 x USB Type‑C 3.1 Gen 1 (up to 5Gb/s) expansion ports for external recording and focus / zoom demand connection. Software updates using USB‑C Port A.
