Blackmagic URSA Mini Pro 4.6K G2
Kosh
7 September 2006
101,093
Εκεί ψηλά.....
Ανακοινωθηκε και η νεα Ursa mini pro.
Mικρες αλλαγες αλλα με νεο σενσορα.
Specs
URSA Mini Pro 4.6K G2 Specs
The original URSA Mini Pro was already a powerful camera with built-in ND-filters, XLR audio, and plenty of recording formats available. The URSA Mini Pro 4.6K G2 brings some new features like:
Super 35mm 4.6K sensor with Blackmagic Design Generation 4 Color Science.
Project frame rates up to 60 fps and off-speed slow motion recording up to 120 fps in 4.6K, 150 fps in 4K DCI and 300 fps in HD Blackmagic RAW.
Support for Blackmagic RAW files in Constant Bitrate 3:1, 5:1, 8:1 and 12:1 or Constant Quality Q0 and Q5 as well as ProRes 4444 XQ, ProRes 4444, ProRes 422 HQ, ProRes 422, ProRes 422 LT, ProRes 422 Proxy recording at 4.6K, 4K, Ultra HD and HD resolutions.
Fifteen stops of dynamic range.
2, 4 and 6 stop neutral density (ND) filters with IR compensation.
Interchangeable lens mount with EF mount included as standard. Optional PL, B4 and F lens mounts available separately.
Built-in dual C-Fast 2.0 recorders and dual SD/UHS-II card recorders allow unlimited duration recording in high quality.
High-speed USB-C expansion port for recording directly to an external SSD or flash disk.
Standard connections, including dual XLR mic/line audio inputs with phantom power, 12G-SDI output for monitoring with camera status graphic overlay and separate XLR 4 pin power output for viewfinder power, headphone jack, LANC remote control, and standard four pins
12V DC power connection.
4-inch foldout touchscreen for on-set monitoring and menu settings.
Includes a full copy of DaVinci Resolve software color grading and editing software.
