- 28 August 2006
- 1,046
πωλειται σε αριστη κατασταση,το χρωμα του ειναι το ασημι.Κ εχει εξωτερικη τροφοδοσια.
Frequency Response:
20Hz-20kHz +/- .05dB
Maximum Output:
15 volts unbalanced, 30 volts balanced
IMD/THD: <0.0015% at 3 volts out
Sensitivity:
Balanced inputs: 1.00 V
UnBalanced line level inputs: 500 mV
Rated Noise:
-100dB (Ref. 500mV unbalanced input, 20-20kHz)
-103dB (Ref. 1 volt balanced input 20-20kHz)
XLR Connector Pin out (Balanced I/O):
Pin 1 ground, pin 2 positive, pin 3 negative
Features:
2 pair balanced female XLR inputs
1 pair balanced male XLR outputs
5 pair RCA inputs
4 pair RCA + 1 pair phono inputs (BP-20/25P and BP-
20/25MC only)
4 pair RCA + 2 SPDIF digital inputs (BP20/25 DA only)
2 pair RCA outputs
1 tape loop
Dimensions:
Standard version: 17” x 1.75” x 11”
43.18cm x 4.44cm x 28cm
Rack mount version: 19” x 1.75” x 11”
48.26cm x 4.44cm x 28cm
Weight: 17 lbs (7.5 kg)
Η κατασταση του ειναι υπεραριστη κ εχει υπολοιπο 17 χρονια ακομα στην εγγυηση.Η τιμη πωλησης του στα 950 ευρο.
Frequency Response:
Maximum Output:
Sensitivity:
Rated Noise:
Features:
5 pair RCA inputs
20/25MC only)
2 pair RCA outputs
1 tape loop
Dimensions:
