- 17 June 2006
- 2,756
Έχει πάρει το μάτι σας αν πωλείτε στην Ελλάδα το κάτωθι drive ?
http://www.sonystyle.com/is-bin/INT...&INT=sstyle-SonyStyleRoot-homefeature-BWU100A
Sony’s first generation Blu-ray Disc drive for the computer offers the best of all worlds by recording virtually all BD/DVD/CD disc formats in one internal package. The BWU-100A drive supports recording both 50GB and 25GB BD-R (write once) and BD-RE (rewritable) discs, as well as 4.7 GB DVD+R/+RW/RAM, 8.5GB DVD+R Double/Dual Layer, and CD-R/-RW discs. Because you can store up to 4 hours of 1080 HD video on a single dual layer 50G BD disc, the BWU-100A is the perfect solution for keeping High Definition video shot on your HDV camcorder in native HD. Boasting up to 50GB of online, random access storage, BD discs are ideal for computer backup and data storage applications. Since the BWU-100A can record DVDs and CDs, all your burning projects can be handled by a single drive. Comprehensive Cyberlink® software suite is included to author BD and DVD discs as well as general disc burning for BD/DVD/CDs. Works with Windows® XP and Windows 2000 PCs.
Record up to 50GB data or 4 hours of 1080 HD video to a single BD disc
Keeps HD video in native 1080 format
Multi-format Drive Burns BD, DVD, and CD discs
Store up to 50GB on a single BD-R/-RE disc
Ideal companion for a HDV camcorders
Easy to install internal PC drive
Works with Windows® 2000/XP
Back Up Your Computer, Make Music Discs, and More
