C-tech HD 6600 SST
Ο δεκτης C-Tech HD 6600 SST είναι πιο παλιός και έχει τρια tuner, 2 δορυφορικά και ένα επίγειο. Και είναι λινουξ όπως ο ΕΤ 9000.
  • High-Definition Personal Video Recorder (HD PVR)
  • 2x DVB-S/DVB-S2 Satellite Tuners (MPEG-2, MPEG-4 & H.264)
  • 1x DVB-T Terrestrial Tuner
  • Output resolution 576p & 576i, 720p, 1080i
  • HDMI & Component Output (YPbPr) with Upscaler to Improve Picture Quality
  • 2 Smart Card Reader & 2 Common Interfaces (2CI)
  • MP3 player and JPEG viewer via internal HDD or USB flash Drive (memory stick)
  • Multisatellite search.
  • On-screen display with true color full resolution.
  • DiSEqC control version 1.0, 1.1, 1.2 and USALS compatible.
  • Enhanced 16 favorite channel groups.
  • Powerful channel control by favorites, lock, skip, move and delete function.
  • Channel sort by alphabet, transponder and CAS.
  • Multilingual OSD Menu : English, Spanish, Portuguese, French, German, Italian, Turkish, Arabic, Persian, Russian, Greek, Czech, Romanian.
  • Extended EPG and program reservation on EPG.
  • Teletext & Subtitle by OSD and VBI
  • Last channel memory function.
  • Total 10,000 channels programmable.
  • Factory default channel list
  • Fully Featured VFD text Front Panel Display
  • Sensitive Tuner
  • Support 4:2:0
HD Satellite & HD Terrestrial Receiver with Blindscan + Ethernet + + 10,000 Channels + Front & Rear USB 2.0 PVR Ready Ports: Recording, Timeshift, Music/JPEG & Software Download 1x Conax Card Reader Slot + 2x CI Sot + HDMI & Component output....
Features
2 DVB-S/DVB-S2 Satellite Tuner & 1 DVB-T Terrestrial Tuner compliant (MPEG2 / MPEG4 / H.264)
Video resolution 576i & 576p, 720p & 1080i supported
HDMI & Component Output (YPbPr) with Hardware Upscaler to Improve Picture Quality
Very Fast & Detailed Hardware Blind Search (power scan)
Ethernet Communication Port
2x USB Ports ( 1x Front + 1x Rear Ports)
10,000 TV & Radio Channels
USB 2.0 PVR Ready via USB External Device or an internal HDD
USB PVR Features: Rewind/Forward, Slow Motion Rewind/Forward, Timeshift (Pause Live TV) & Record
Scrambled/Free-To-Air (FTA) Channels & Record current channel and playback a recording at the same time
Music player & JPEG viewer via USB 2.0&HDD
Fast Software & Channel List download via USB 2.0
2 Scart Outputs with RGB Support
Super sensitive tuner for very weak signals
Dolby Digital Optical S/PDIF
Dolby Digital by HDMI
DiSEqC 1.0 / 1.1 / 1.2 & 1.3 (USALS) compatible
Auto Navigation system – select as many satellites as you want to search
On-screen display with true full color resolution
Enhanced 16 Favorite channel groups
Channel control by: Favorites, Lock, Skip, Move & Delete
Channel sort by: All, Alphabet, Transponder & CAS
Parental, Installation & Receiver Lock
Multilingual OSD Menu: English, Spanish, Portuguese, French, Dutch, German, Italian, Turkish, Arabic, Russian, Greek, Czech, Romanian, Persian
Fast & Easy-To-Use Menu System
Various games
Software & channel list upgrade via RS-232C: PC to STB, STB to PC, STB-STB and USB
Zoom function on Pause & Live channel
Multi picture display
SCPC & MCPC receivable from C/Ku band satellites LNBs supported: Universal, Single, Single S & C band wideband LNBs
4:3 & 16:9 Screen Formats
90-250V AC 50/60 Hz
LNB Short Circuit protection onboard
ειναι η δεν ειναι ρε παιδια open source
τον εχει καποιος αυτο το δεκτη?
Γινεται να τον παραγει η ιδια εταιρεια με τον ΕΤ-9000 και να μην ειναι linux?
