CoreAVC 1.8
Δεβελέκος Στράτος
1,626
CoreAVC H.264 Video Codec - Version 1.8.0.0 (20080831)
- Add: About tab
- Add: Help tab (describing filter options)
- Add: Picture levels adjustment tab
- Add: System Tray icon
- Add: Support for AVC Lossless 4:2:0
- Add: Support for new standard aspect ratios
- Fix: Rearranged options tab
- Fix: Renamed Blend deinterlace to Single Field
- Fix: Fix Bob deinterlacing with Matroska files
- Fix: Fixed Aggressive Deinterlace function
- Fix: Better recovery point handling
- Fix: Improved filter stability
http://www.coreavc.com
