CoreAVC 3.0
lykman
29 June 2006
5,798
Aθήνα
Αν και νομίζω ότι πια το coreavc έχει χάσει την προτίμηση του κόσμου, ειδικά που τώρα πια υπάρχουν δωρεάν αξιόλογοι και ποιοτικοί decoders, ίσως με την 3.0 την ξανακερδίσει.
CoreAVC 3.0 Now Available for Purchase!
This is to notify you that after almost 2 years of work CoreAVC 3.0 is
now Available!
CoreAVC 3.0 is a major milestone for us here at CoreCodec and adds
features like 9/10 bit support, Full DXVA 2, DXVA 1, GMA support, DXVA
fallback, Intel Media SDK support, New Assembly 'Core', etc.
What's new in 3.0?
CoreAVC H.264 Video Codec - Version 3.0.0.0 (20110906)
- ADD: 9 bit support
- ADD: 10 bit support
- ADD: DXVA fallback to software
- ADD: Intel Media SDK Support (DXVA2)
- ADD: Intel GMA Support (DXVA2)
- ADD: 10 bit output format (P010)
- ADD: 16 bit output format (P016)
- ADD: Directshow dithering when filter output is downsampled
- ADD: Improved DXVA handling for interlaced streams
- ADD: Colorspace conversion from 10 bit formats to 8 bit formats
- ADD: DXVA 2 Long slice support
- ADD: Initial 4:4:4 integration (No decode support yet)
- ADD: New assembly engine
- ADD: New assembly IDCT
- ADD: New assembly motion compensation
- ADD: New assembly inter-prediction
- ADD: New assembly weighted prediction
- ADD: New assembly 9-bit
- ADD: New assembly 10-bit
- ADD: Improved assembly 8 bit performance
- CHG: Use container AR when there is no stream AR
- FIX: Improved Frame order handling
- FIX: Hardware deinterlacing field order
- CHG: DXVA increase max buffers
- CHG: Sanitize sample stop times for buggy splitters, for hardware
deinterlacing compatibility
- FIX: Better recovery point handling, reduces artifacts for poorly
cut streams
- SDK: Updated xcode support for iOS and OS X
- SDK: Improved APIs
- SDK: Fix: Missing APIs
- SDK: Initial support for MVC (CoreMVC) integration
Haali Media Splitter - Version 1.11.233.7 (20110830)
- FIX: Various DTS Audio bugs
- ADD: Improved DTS support
- ADD: Support for MVC 3D videos
Αν έδιναν δωρεάν αναβάθμιση σε όλους, θα το δοκίμαζα. Το πλήρωσα μια φορά και δεν το χρησιμοποιώ έτσι κι αλλιώς...
Κι εγω το εβαλα στην αρχη, αλλα τωρα ffdshow που ειναι δωρεαν και κανει τα παντα
