Advance Acoustic Ultim UM 40
Πωλούνται σε μοναδική τιμή 250 ευρώ! από 300 που τα είχα βάλει και περίπου 800 που κάνουν σήμερα καινούργια
Είναι Αγορασμένα το 2009 χωρίς συσκευασίες και χωρίς τις Original ακίδες. (Δίνονται με custom ποδαράκια πάχους περίπου 2 cm).
Κατά τα άλλα είναι σε πολύ καλή κατάσταση (με WAF 10+).
http://www.avstore.ro/en/speakers/ad...ic-ultim-um40/
http://www.skroutz.gr/c/9/hxeia-hi-f...se=ultim+um+40
The UM 40 is a high standard column speaker able to reproduce music in the lowest frequencies with an exceptional smoothness while conveying tones truly.
Advance Acoustic had decided to design the loudspeakers in three basic categories :
- Cabinetwork
- Speakers
- Filter circuit
Cabinetwork :
All Advance Acoustic speakers cabinetwork is made in medium due to its rigidity and manufacturing precision ; Moreover, partitions and strenghthening pieces prevent any vibration or interference. The internal volume of the speaker is worked out in minute details as are the dimensions of the tuning hole for every speaker used.
Speakers :
Advance Acoustic speakers are made according to specifications in a rigorous manner in order to meet with the wished-for results. Boomers are provided with a treated paper membrane in order to get a more neutral sound and pure copper moving coils are wired on capton. To prevent any harshness and enhance smoothness, tweeters have either plastic or impregnated fabric membranes. Moving coils are cooled in ferrofluid.
Filter circuit :
Despite the care brought to cabinetwork and the choice of the best speakers, the final result is determined by the filter. Advance Acoustic has devised an accurate rigorous filtering technique respecting the acoustic and electric phases. A choice of the best components, air selfs, polypropylene condensers, high standard ceramic resistances, non-radiant positioning of the componants and judicious cuts frequency.
- Cabinetwork
- Speakers
- Filter circuit
Cabinetwork :
Speakers :
Filter circuit :
