Δεν μπορούν να μου στείλουν PM.
billytsik
2 January 2009
361
Internet
Έχω επιλέξει όλα τα κουτάκια το options control panel private messaging αλλά μου παραπονιέται κόσμος ότι δεν μπορεί να μου στείλει PM.
Τι να κάνω ?
This forum features a private messaging system, which allows members to send messages to one another privately.
If you do not want to send or receive private messages, you may disable the private messaging system.
Enable Private Messaging
The forum can send a message to your email address to inform you when someone sends you a private message.
Receive Email Notification of New Private Messages
If you are browsing the forums when you receive a new private message, the system can pop-up a notification box informing you of the new message.
Show New Private Message Notification Pop-up
Καλημέρα,
είχες επιλέξει και το κουτάκι
Receive Private Messages only from Contacts and Moderators
Που δε χρειαζόταν προφανώς
na po to krima mou den fenete !
