Πωλουνται οι παρακατω ενισχυτες σε πραγματικα αριστη κατασταση .
Τα χρωματα ειναι αυτα που βλεπετε στις φωτο .
Τιμες , ειλικρινα δεν ξερω τι να βαλω ..αναμενω τις προσφορες σας.
* Marantz PM7000
Saying Marantz are known for making amplifiers would be like saying god is known for creating the world...
Great amplifier.
From the outside, the unit is full of clean lines, with soft rounded edges rather than classic corners. It's solidly made, as attested by its weight of 12.3 kg (app. 28.3 lbs).
Marantz quotes its specifications as 2x95W into 8 Ohms, 20-20,000 Hz, with no more than 0.03% THD. This rises to 2x150W into 4 Ohms.
Maximum power output is quoted as 120/195W into 8/4 Ohms, the damping factor is quoted as 150 into 8 Ohms and response is given as -1dB down at 10 and 65,000 Hz.
The Marantz PM-7000 Integrated Amplifier is a highly versatile and flexible stereo music system control center that delivers superb sonic performance at an extremely attractive price. It offers music lovers uncompromising audiophile sound quality and unmatched flexibility of operation. The elegantly styled PM-7000 combines exceptional sonic purity with a wealth of performance and convenience features, making it the ideal centerpiece for creating a true high-end music system.
The PM-7000 has 95 watts per channel power output (into 8 ohms), featuring Marantz’s unique Linear Drive Power Supply (LDPS), which operates as a constant voltage supply to effortlessly drive even exotic high-end loudspeakers that present difficult loads. Also included is an HDAM (High Definition Amplifier Module) fully discrete copper-shielded output stage for wide bandwidth, low noise and exceptional dynamic range. Symmetrical single push-pull amplifier topology provides maximum sonic purity and accurate imaging. Premium-quality parts and construction ensure superb sound quality, including audiophile-grade capacitors in critical signal path applications, strengthened mechanical construction and other refinements.
The PM-7000 has seven source inputs including moving magnet (MM) phono input, to accommodate a wide variety of music sources. All functions of the PM-7000 can be controlled by the supplied remote, including volume adjustment. The PM-7000′s rear-panel D-BUS connector allows integrated operation of a complete Marantz system.
Record Output Selector function allows listening to one source while recording another. In addition, the PM-7000′s tape monitor/CD-R connections provide real-time monitoring capability of recording quality. The PM-7000′s Source Direct switch bypasses the tone control circuitry for ultimate signal purity. A processor loop allows connection of a graphic equalizer or other audio processor.
*Denon AVR-3802 7.1 Channels Receiver
Xαρακτηριστικα : http://www99.epinions.com/specs/_Denon_AVR_3802__617326
http://www.epinions.com/review/_Denon_AVR_3802__617326/content_69172235908
* Marantz PM7000
Great amplifier.
