Denon’s HDMI 1.3 Receivers
February 6, 2007
Follow Up: Denon’s HDMI 1.3 Receivers
Back in November Audio DesignLine unveiled some of the first details surrounding (pun intended) Denon’s forthcoming A/V receivers with HDMI 1.3 support, we now have a few more tentative details about the new ‘08’ series of receivers from Denon. It appears as if the receivers will be rolled out in two waves, the first wave in July will include the AVR-4308ci and AVR-3808ci with the AVR-1508, AVR-1708 and AVR-2808 following in September.
Again these are tentative details but should remain accurate baring any last minute launch snafus. The AVR-4308ci ($2,499) will sport four HDMI 1.3 inputs with two parallel HDMI outputs, support for internal Dolby TrueHD and DTS-HD audio decoding over HDMI, auto lip-sync correction, 8-position Audyssey MultEQ, Ethernet & Wi-Fi capabilities for internet radio and presumably support for Windows Media PlaysForSure functionality. The 4308 will also support second zone component video output and digital to analog conversion for multi-zone applications.
The AVR-3808ci (also tentatively expected in July) will retail for $1,599 and features four HDMI 1.3 inputs, support for internal Dolby TrueHD and DTS-HD audio decoding over HDMI, auto lip-sync correction, 6-position Audyssey MultEQ, Ethernet connectivity and again presumably support for Windows Media PlaysForSure. The 3808ci also supports digital to analog conversion for multi-zone applications. Both the AVR-4308ci and AVR-3808ci are said to have had their on-screen graphical interfaces redesigned as well.
The second wave of receivers in September will include the AVR-1508, AVR-1708 and AVR-2808 (no pricing as yet). The AVR-1508 AVR-1708 will support HDMI 1.3 but ‘switching mode’ only, in a nutshell that means that they will support HDMI audio, ‘Deep Color’ and 1080p pass-through but not internal Dolby TrueHD and DTS-HD processing, although you can still achieve lossless audio from Blu-ray and HD DVD output as PCM from the players over HDMI.
The AVR-2808’s HDMI 1.3 path is said to offer the same functionality as the AVR-4308ci and AVR-3808ci, i.e. internal Dolby TrueHD and DTS-HD decoding as well as auto lip-sync correction. Good stuff indeed, I can’t wait to get my hands on the AVR-3808ci.
http://www.hometheaterblog.com/hometheater/2007/02/follow_up_denon.html
Thanks Παναγιώτη.
Και ξαναρωτώ: Η εικόνα στην τηλεόρασή μας ή ακόμα περισσότερο στο προβολικό μας, θα πηγαίνει αναγκαστικά μέσω του A/V; Αν ναι, ζωή σε λόγου μας....
Re: Απάντηση: Denon’s HDMI 1.3 Receivers
Thanks Παναγιώτη.
Δηλαδη ειναι καλυτερα λες το hdmi να μην περναει απο τον AV (Ρωταω για να μαθω)
Denon AVR-4308ci Φωτογραφιες
http://www.hometheaterhifi.com/volume_14_1/show-report-ces-2007-page-49.html
Thanks Παναγιώτη.
πιστεύω ότι σε βάθος χρόνου θα βγουν players με δύο hdmi out.
Αυτό που αποκλείεται είναι να περάσουν τα νέα φομα ήχου από άλλη έξοδο πλην της hdmi
Δυστυχώς, με την εφαρμογή του HDMI 1.3 σαν κοινή δίοδο μεταφοράς τόσο του σήματος DD trued και HD video, μόνο μία λύση υπάρχει. Πηγή με δύο ή περισσότερες εξόδους HDMI, κάτι που δεν φαίνεται.
Το μεγάλο σημερινό πρόβλημα όμως για μένα, είναι το ότι κοντά ένα χρόνο από το λανσάρισμα του HD και 9 μήνες από το 1.3, ΔΕΝ υπάρχει η αλυσίδα μεταφοράς σε ψηφιακή μορφή. Αυτό είναι απαράδεκτο για όλες τις εταιρείες που συμμετέχουν στα 3 φόρμα (HD-DVD, Blue-Ray και HDMI).
Ακόμη δεν διαφαίνονται στον ορίζοντα και λύσεις για το HTPC.
Υποθέτω αναφέρεσαι στον περιορισμένο αριθμό players και στην ανυπαρξία αποκωδικοποιητών - σωστά???
Που εντοπίζεις το πρόβλημα στο HTPC???
Απάντηση: Re: Απάντηση: Denon’s HDMI 1.3 Receivers
Ανυπαρξία; Μόνο;
Δεν υπάρχουν έξοδοι ψηφιακών σημάτων για HD (audio-video).
Τέσπα αυτό δεν είναι για ’δω. Αλλά για δείτε τις αναφορές στο HTPC, και θα καταλάβετε.
Μόλις θα χρειαστούν πραγματικά - μόλις δηλαδή δημιουργηθεί η "αλυσίδα" που αναφέρεις - να είσαι σίγουρος ότι θα λυθεί το θέμα με τα PC... όπως άλλωστε λύνονται και όλα τα PC-σχετικά θέματα...
Ζωή σε λόγους μας indeed
Εϊναι λιγάκι εκνευριστικό το ζήτημα.. θα δείξει ...
Thanks Παναγιώτη.
μα HDMI 1.3 θα πει και ηχος ομως ,οχι μονο εικονα!
