DK Designs
audiophile62
9 February 2007
1,292
Αθηνα-Γλυφαδα
LSA Standard
Hybrid Integrated Amplifier
"...rich, uncolored and captivating... silky and organic..."
Robert J. Reina, Stereophile, June 2006
The LSA Group has offered a remarkable line of tube/solid state hybrid integrated amplifiers under the name ‘DK Design’.
LSA has just released our newest line of Integrated Amps under our own banner.
Featuring a new industrial design, upgraded coupling capacitors, improved speaker binding posts, and a variable line-out for subwoofer connection, the new LSA amps are truly giant killers in the industry.
The LSA ‘Standard’ amplifier is the latest update of the renowned ‘DK Reference MKIII’ - listed as a 2006 Stereophile Recommended Component. With advanced vacuum tube circuitry in the pre-amp section and twin toroidal solid-state transformers, this unique amplifier exudes strength and musicality - approximately 78 pounds and 150wpc of it. Complete with phono stage and remote.
Finish
Rated Power (8Ω)
Total Harmonic Distortion
Recommended Loading Impedance
Frequency Response
Signal-to-Noise Ratio
Channel Separation
Input Impedance
Input Sensitivity, Analog
Input Sensitivity, Phono
Inputs
Dimensions (Imperial)
Dimensions (Metric)
Weight
Warranty
Silver, black accents
≥ 150 wpc
≤ 0.1% (1KHz)
4-8Ω
20Hz-32KHz (±1dB)
≥ 90dB
≥ 60dB (1KHz)
47KΩ
≥ 200mv
≥ 4mv
1 balanced, 3 single-end, 1 phono
17" (W ) x 9 1/4 " (H) x 19 1/2" (D)
43 cm (W) x 23.5 (H) x 48 (D)
78lb / 38kg
5 years
Αυτοί, αν θυμάμαι καλά, είναι οι γνωστοί μας CAV σε πιο "Hi-End" συσκευασία και με πιο "Hi-End" τιμές.
