DMM:release-candidate-dm800_20090822
AlexT_
10,461
Enigma2: Release Candidate 2.5
Machine: Dreambox dm800
Date: 20090822
Issuer: Dream Multimedia TV
Link: http://dreamboxupdate.com/opendreambox/1.5/dm800/images
MD5: 611e28df405e70f4305cf887a204fe9e
Description:
changelog release candidate 20090721 -> 20090822
enigma2/plugins (20090721 -> 20090822)
fix incorrect network-enabled-indicator in network setup
more robust PMT streamtype detection
add dishnetwork scan support
fix dvb subtitles on sky brazil
some dvb-text encoding fixes/improvements
serbian translation added
slovenian translation added
slovakian translation added
fix subtitle handling on timeshift/live transition
fix playback of ts recording with pmt changes (regional service windows)
add support for BBC-HD dvb subtitles
motor turning improvements
fix timeshift/live transition when skipping forward
fix parallel recording of the same event on different services
add crashlog auto submitter plugin
add genuine dreambox plugin
hide all screens on shutdown (this fixes non empty oled display after shutdown in some conditions)
drivers (20090720 -> 20090820)
fix for playback of MPEG2 HD 1080p (converted H264 file with mkv2vob was not working.. green screen)
improved H264 compatibility (higher bitrates, higher level, more reference frames)
vtuner support for settings tuner informations added (still experimental)
λινκ:
http://dreamboxupdate.com/opendreambox/1.5/dm800/images/release-candidate-dm800_20090822.nfi
Απάντηση: DMM: release-candidate-dm800_20090822
Διορθωτική έκδοση
release candidate 20090822a
Date: 20090822
MD5: 5d74b56fb768267ea92cb37c097ce6dd
Description:
changelog release candidate 20090822 -> 20090822a
enigma-plugins (20090822 -> 20090823)
small fix in genuinedreambox plugin
drivers (20090820 -> 20090822)
fix deinterlacer handling in auto mode
λινκ:
http://dreamboxupdate.com/opendreambox/1.5/dm800/images/release-candidate-dm800_20090822a.nfi
Προσωπικά δεν εγκατέστησα τη νέα RC έκδοση, αλλά αναβάθμισα το experimental και ..απέκτησα και τον νέο Second Stage Loader #74.
Product Name: DM800
Booloader version: Dreambox Second Stage Loader BUILD #74, built 20090820
Flash Size 64 MB
Πάντως τόσο στο Gemini forum όσο και σε αυτό της DMM αναφέρονται παράπονα για την ποιότητα της εικόνας που οφείλονται στους νέους drivers..
Re: Απάντηση: DMM:release-candidate-dm800_20090822
και οχι μονο στα sd καναλια
Thank you AlexT_,
Συγνώμη αλλά αυτό εγκαθιστάτε ξεχωριστά από το Gemini 4.40 η κάποιο άλλο image?
Επίσης μπορεί να γίνει ξεχωριστή αναβάθμιση του Second Stage Loader ?
ειναι ενα κανονικο image το οποιο περνας στην flash αλλα αν εχεις experimental στην flash τοτε κανε απλα update
leo, παρόλα αυτά δε μπορεί να συγκριθεί με το experimental γιατί το RC περιλαμβάνει μόνο τα σταθερά πακέτα, ενώ το πρώτο μαζί με αυτά και πολλά beta. (στο θέμα σταθερότητας εννοώ)
