Dream Elite BH 1.2 OE1.6 DM800 Multiboot
leo06
14 October 2007
6,968
Πάτρα
This is a image for DM800hd with new OE 1.6 and new kernel 2.6.18-7.3
Specifications:
Oe version: 1.6
Kernel version: 2.6.18-7.3
Dreambox Secondstage: #75
Dreambox Dvb drivers: 20100322
Enigma2 CVS: Experimental 20 mar 2010
MeoBoot version: 0.96xDm800HD only
Bootlogos: by Army
New: Device Panel with devices mapping
Fixed: Epg Search (no more using VirtualKeyboard).
Fixed: Nfs Server (auto-restart)
ECM TIME FIXED
Meoboot: This version of Meoboot can be installed on Usb, Cf, SD and on Hdd too.
Skin: Beyoncè 6 HD by Matrix10 awesome HD skin with large size fonts and panels
Warning: THIS IMAGE HAVE THE NEW KERNEL AND CANNOT BE INSTALLED IN MULTIBOOT. THIS IMAGE HAVE TO BE INSTALLED IN FLASH
Warning2: AFTER IMAGE INSTALLATION GOTO DEVICES PANEL AND MAP YOUR DEVICES. REMEMBER TO INSTALL MEOBOOT ONLY AFTER YOU HAVE MAPPED YOUR DEVICES.
Warnig3: ONCE YOU HAVE INSTALLED MEOBOOT DON'T MOVE DEVICE IN WICH MEOBOOT IS INSTALLED. (AS FOR EXAMPLE IF MEOBOOT IS INSTALLED ON USB DON'T REMAP THE DEVICE OF MEOBOOT ON USB2)
Warning4: YOU CAN INSTALL IN MULTIBOOT WITH THIS IMAGE ONLY IMAGES OE 1.6 WITH THE NEW KERNEL.
NEW NEW NEW: NEW DEVICE PANEL WITH MOUNTPOINTS FOR DEVICE MAPPING
Short instructions
1.Map/mount Device (red button)
(Example1: for Multiboot as /media/usb)
(Example2: as hdd /media/hdd)
2.Format Device (yellow button)
3.Map/Mount Device after format (red button)
After each step
we need image restart
This image is a final Black Hole serie, entirely rewrote and recoded to have maximum stability and performance.
We remember that black hole serie images have the best epg system available:
- Integrated Openepg for Sky-it Sky-uk Sky-Au
- Latest CVS enigma2 Epg features
- New external epg.dat system.
Therefore, each board or community can create its favourite EPG data files, and upload it to a web space. Community members can then download it from that server.
This feature offers additional benefits, such as:
EPG download increased speed
EPG download from any channel
EPG scheduled download also during standby
User set EPG Providers Add/Remove
New:
New Boot logo by Army
WARNING: THIS IMAGE INCLUDE THE NEW KERNEL 2.6.18-7.3. FOR THIS REASON YOU HAVE TO INSTALL IN MULTIBOOT ONLY LATEST IMAGES BASED ON OE 1.6 WITH NEW KERNEL.
Main Function Keys
Button 1xOK = Light Info Skin
Button 2xOK = Extra Info Skin
Button Blue = Dream ELite Blue Panel
Button 1x Blue + 1x Red = Dream Elite Epg Panel
Button 1x Blue + 1x Yellow = New System Monitor Panel
Button Blue-Long-Push = Extensions
Button Green = Dream Elite Green Panel
Button Green-Long-Push = Subservices
Button 1x Green + 1x Red = CCcam Info
Button Red = Start Record
Button Yellow = Time Shift
Addons
Dedicated Addons Server
Download and install additional packages from Dream Elite server
Infobar/OSD
Enigma2 Analogic Clock
Channel Orbital Position
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information
Dream Elite Panels features
1) Blue Panel
Setup
Black Hole Cron Manager
OSD Settings
Devices Manager
Kernel Modules Manager
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Black Hola Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel
CCcam Info
Service Info
Enigma2 Settings
About
Memory
Space
CPU
Process
AutoCam
Select EMU by Channel
2) Green Panel
CCcam Info
Fast Plugin
Addons
Addons Download Manager
Manual Install Del packages
Manual Install IPK packages
Addons Uninstall Panel
Dream Elite Statistics
Scripts
Many thanks to the Beta Testers Team.
Many thanks to Rytec for all the epg servers providing precompiled Epg.dat for Dream Elite Image (add skyIta and SkyDe).
Credits
Many Thanks to Rytec for external epg
E2 Sky Epg loader integration by MaxZ4.
Many Thanks to lukkino (VDR-Italia) for opentv source code.
Many thanks to Reinh@rd for the satellites.xml file.
Many thanks to Seddi for Grab update
ATTENTION!
THIS IMAGE HAVE TO BE INSTALLED IN FLASH.
THIS IMAGE CANNOT WORK IN MULTIBOOT WITH DIFFERENT IMAGES IN FLASH. DREAM ELITE TEAM WILL NOT SUPPORT IMAGES NOT INSTALLED IN FLASH.
This Images doesn't contain any keys nor softcams.
Backups or other modified Images are not supported!
http://www.dream-elite.net/forum/attachment.php?attachmentid=1196&d=1269438431
