Nεο media player απο την hdi με τιμη κοντα στο χιλιαρικο!
Θα κανει τα παντα (χωρις απαραιτητα να συμφερει) και θα εχει hi grade audio components για τους μουσικοφιλους...
Hi-End Features
Hi-End power supply: high-performance large toroidal power transformer ensures a low level of interference in the power supply section and prevents possible distortions in the analog audio output, making the sound more clear and transparent, making music images articulated, precise and focused, and making the video more vivid and intense.
Hi-End audio outputs: the highest quality balanced XLR stereo outputs as well as the analog 7.1 multichannel RCA outputs, served by a high performance stereo DAC WM8741 from Wolfson Microelectronics (supports from 16 to 32 bits and sampling rates up to 192 kHz).
Balanced AES/EBU digital output: AES/EBU supporting PCM-encoded audio at 48 kHz or CD-audio at 44.1 kHz can be used to deliver digital stereo sound of the highest quality.
High-quality music playback: play very high-quality (up to 192 Khz / 24-bit) music files in various formats (FLAC, Monkey's Audio APE, WAV/PCM, DTS, etc).
Big weight: big weight of the chassis and solid body provides a low vibration level of the optical disc in the drive as well as the internal HDD, minimizing the level of the disc tremor, and allowing to read data with higher accuracy.
IR input: get more flexibility for player installation (connect an external IR eye) or connect the player to external control platforms.
RS-232 control port and 12V trigger input: even more flexibility for integration of the player with external control platforms.
PURE AUDIO button on the front panel: listen to the music directly, with video output electronics disabled, that helps to get even better audio quality.
DIMMER button on the front panel: control the brightness of the built-in display or turn it off completely.
Detachable 19" rack brackets: put the player into a standard rack mount.
Πιο πολλα εδω...
http://dune-hd.com/hd_players/current/146-hdi-dune-pro.html
Hi-End Features
Πιο πολλα εδω...
