EIZO CRT 19" T766
STELIOS
27 August 2006
2,072
Πωλειτε μονιτορ CRT μαρκα EIZO μοντελο Flexscan T766 στην τιμη των 450 ευρω, με τα παρακατω χαρακτηριστικα:
FlexScan® T766
50 cm (19 inch) Class Color CRT Monitor
FlexScan T766 Image
Specifications
CRT Size 50 cm (19 inch) class, 90° deflection Tension Mask
CRT Phosphor Pitch Center: 0.24 mm, Edges: 0.25 mm
CRT Surface Treatment Super ErgoCoat®
Scanning Frequency H: 30 - 115 kHz V: 50 - 160 Hz
Dot Clock 280 MHz (typical)
Input Signals RGB Analog
Input Terminal D-Sub mini 15 pin and BNC × 5 (switchable)
Active Display Size 362 mm (H) × 271 mm (V) / 14.3" (H) × 10.7" (V)
Viewable Image Size Diagonal: 452 mm / 17.8"
Recommended Resolution 1280 dots × 1024 lines @ 107 Hz1
Maximum Resolution 1920 dots × 1440 lines @ 76 Hz1
Screen Control ScreenManager®, ScreenManager Pro for USB, One Touch Auto Adjustment Function (Auto-Sizing)
Power Requirements AC 100 - 120V, 200 - 240V: 50 / 60 Hz
Power Management System VESA DPMS
Power Consumption 120 watts
Power Save Mode 1 Less than 10 watts
Power Save Mode 2 (Off) Less than 3 watts
OSD Language English
Plug & Play VESA DDC 2B
Dimensions 452 mm (W) × 455 mm (H) × 478 mm (D)
17.8" (W) × 17.9" (H) × 18.8" (D)
Net Weight 26.7 kg / 58.9 lbs
Tilt / Swivel 10° up, 4° down / 45° right, 45° left
Certifications and Standards TCO'992 , TÜV ECO Circle 2001, TÜV/GS, c-Tick, CE, CB, UL 1950, CSA C22.2 No.950, FCC-B, Canadian ICES-003-B, TÜV/S, VCCI-B, EPA ENERGY STAR® Program, DHHS (DNHW), German X-Ray Law, CCC
USB Standard USB Standard Rev. 1.1
USB Ports 1 upstream, 4 downstream
Supplied Accessories AC power cord, setup guide, signal cable (D-Sub mini 15 pin), EIZO USB Cable, EIZO CRT Utility Disk (ScreenManager Pro for USB, ICC profile), warranty registration card
1 Maximum refresh rate for this resolution.
και ενα link:
http://www.eizo.com/SUPPORT/discontinued/crt/t766.asp
το μοντελο αυτο ειναι απ τα ελαχιστα μονιτορ που εχουν και εισοδους BNC.
