Emotiva UMC-1
Status
Not open for further replies.
mr_rebelos
10 July 2006
11,511
Κερατσίνι
Πωλείτε ο av προενισχυτής (av processor) Emotiva UMC-1.
Μερικά χαρακτηριστικά του:
  • Twin Cirrus® 32 bit dual core DSP’s
  • Decoding support for Dolby Digital, Dolby Digital EX, Dolby Digital Plus, Dolby Digital True HD, Dolby PLIIx, DTS, DTSES, DTS HD, DTS Master Audio, DTS Neo 6, SPDIF, PCM 8 channel (note: some audio formats are only supported via HDMI)
  • Multi-channel Dolby Volume
  • Genesis/ST® Torino high performance scaling engine - featuring a full implementation of the Faroudja DCDi™ image processing suite
  • Intuitive, full color graphical OSD with adjustable transparency presented over live video, including HDMI
  • Emo-Q™ automatic multi-channel room correction and loudspeaker setup. Calibrated measurement microphone included.
  • Quadruple bass manager with independently selectable high and low pass frequencies from 40hz – 250hz, in 5 or 10Hz increments (depending on frequency)
  • Selectable 12db or 24db per octave high pass and low pass filters by channel groupings
  • Independent 11-band graphic EQ with global bass and treble controls by channel groupings
  • Balanced subwoofer output
  • All legacy video inputs can be scaled and output over HDMI at up to 1080p
  • 1080p/24 fps video support
  • Video pass-through mode with 12 bit compatibility
  • HDMI sources can be format converted to component video up to 1080i (subject to Macrovision™ guidelines)
  • HDMI 1.3a Deep Color compliant
  • All inputs are assignable and feature input labeling, selectable decode modes, selectable triggers, etc.
  • 0.5dB level trims on all channels
  • High voltage, low impedance main analog outputs for uncompromised dynamic headroom
Φώτο του προ
Πληροφορίες με πμ. Δεκτή ακρόαση στον χώρο μου. Τιμή 500 (όχι ανταλλαγές).
Γιατι τον πουλησες αν επιτρεπεται; Σκεφτομαι να κανω μια λυση με αυτον τον εμοτιβα προενισχυτη + 5 καναλο τελικο + 2καναλο τελικο για διπλοενισχυση στα μπροστινα ηχεια με active crossover...
Υπαρχει ξαδελφος στην Αμερικη βλεπεις...
Μη λέτε τέτοια γιατί ζηλεύω. Είχα και γω σκοπό (προ κρίσης) να πάρω το σετάκι αυτό, αλλά φοβήθηκα την όλη διαδικασία από USA.
Απάντηση: Re: Emotiva UMC-1
Προς το παρόν είναι ακόμα στα χέρια μου. Συντομα θα δωθεί στον νέο του ιδιοκτήτη. Ο λόγος της απόφασης μου αυτής (όπως και του να δώσω τον 7κάναλο τελικό μου) είναι για να πάω σε πολύ καλό δικάναλο σετ προ-τελικού και το κομμάτι του home cinema να το αναλάνει ολοκληρωμένος av.
Σε περίπτωση που δεν τον πουλήσεις θα με ενδιέφερε εμένα το συγκεκριμένο μηχάνημα. Μπορείς να μου πείς αν δουλέυει το FM tuner του στα μερη μας;
Αν κάτι αλλάξει θα σε ενημερώσω. Σχετικά με το tuner μια φορά που κατα τύχη το έβαλα έπιανε σταθμό. Θα πρέπει να το τεστάρω.
Status
