- 20 May 2009
- 5,856
Dharma D1000 Hybrid Electrostatic Stereo Headphones.
Its design, built around our patented SBESL (Self-Biased Electrostatic) technology, eliminates the need for an external AC connection to provide a polarizing voltage.
The result, not unexpectedly, is high frequency response that extends to 50 KHz, and sweet, nuanced, sound that will take your breath away.
Augmenting the electrostatic HF element for lower frequencies is a 50mm Wagami paper based dynamic driver, which provides not only bass extension to 15 HZ, but palpably impactful mid bass as well.
Specs:
Frequency response15–50 kHz
Nominal impedance
26 Ohms
THD
Less than 0.3% (1 kHz, 1mW)
Sensitivity
95 dB (1 kHz, 1mW)
Configuration
Around the ear, open back.
Standard plug
¼” (6.3 mm) stereo
Weight
380 g (without cable)
Cable length
3 meters
