[Επίσημο] Xiaomi Redmi Note 5 / 5 Pro
airb
25 May 2008
15,717
Λιβαδειά
Τεχνικά Χαρακτηριστικά
[TABLE="class: grid, width: 800, align: center"]
[TR]
[TH="class: spec-table outer_border, align: left"][/TH]
[TH="class: spec-table outer_border"]Redmi Note 5 Pro[/TH]
[TH="class: spec-table outer_border"]Redmi Note 5[/TH]
[/TR]
[TR]
[TD="align: center"]System OS[/TD]
[TD]Android 8.1 (Oreo) with MIUI 9.2[/TD]
[/TR]
[TR]
Display
[/TD]
[TD]5.99'' (15.2cm) (Diagonal)
18:9 full screen display
2160 x 1080 FHD+, 403 PPI
84% NTSC color gamut
Sunlight mode
Night mode
Reading mode
Color temperature adjustment
Standard mode[/TD]
18:9 screen aspect ratio
2160 x 1080 FHD+ resolution, 403 PPI, 1000:1 contrast ratio
450 nits brightness
84% of NTSC color gamut
Sunlight display
Night display
Reading mode
Standard mode[/TD]
[/TR]
[TR]
[TD="align: center"]Processor[/TD]
[TD]Snapdragon 636, Octa-core[/TD]
[TD]Snapdragon 625, 1.8GHz max[/TD]
[/TR]
[TR]
Memory
[/TD]
[TD]4GB / 6GB
LPDDR4X
eMMC 5.0 flash storage[/TD]
[TD]3GB / 4GB
LPDDR4X
[/TR]
[TR]
Battery
[/TD]
[TD]4000mAh, lithium-ion polymer battery
5V/2A charging
QC2.0[/TD]
[TD]4000mAh
5V/2A[/TD]
[/TR]
[TR]
Rear Camera
[/TD]
[TD]12MP primary sensor (1.25μm, f/2.2 aperture)
5MP secondary lens (1.12μm, f/2.0 aperture)
Single tone flash
PDAF
Enhanced low-light photography
HDR adjustments
Panorama
Burst mode
Face recognition[/TD]
[TD]12MP, 1.25μm large pixel
5-element lens, Ζ’/2.2 aperture
Dual LED flash
PDAF
Low light enhancement
HDR
Panorama
Burst mode
[/TR]
[TR]
[TD="align: center"]Front Camera[/TD]
[TD]20MP sensor
1.0μm, f/2.2 aperture
Beautify 4.0
Selfie-light
Selfie timer
[TD]5MP front camera
Beautify 4.0
Selfie-light
Selfie countdown
[/TR]
[TR]
[TD="align: center"]Video
Recording
[/TD]
[TD]1080p video capture, 30 fps
720p video capture, 30 fps[/TD]
[/TR]
[TR]
Sensors
[/TD]
[TD]Electronic Compass, Accelerometer, Proximity,
Infrared, Ambient light, Gyroscope, Hall sensor[/TD]
[/TR]
[TR]
[TD="align: center"]Connectivity[/TD]
[TD]Wi-Fi 802.11ac | WiFi Direct | WiFi Display
Bluetooth 5.0[/TD]
[TD]WiFi 802.11ac | WiFi Direct | WiFi Display
Bluetooth 5.0[/TD]
[/TR]
[TR]
[TD="align: center"]Dual SIM
[/TD]
[TD]Nano-SIM + Nano-SIM or Nano-SIM + micro SD[/TD]
[/TR]
[TR]
[TD="align: center"]GPS Navigation[/TD]
[TD]GPS, AGPS, GLONASS, BeiDou positioning[/TD]
[/TR]
[TR]
Package
[/TD]
[TD]Redmi Note 5 Pro
Power adapter
USB 2.0 cable
Warranty card
User guide
SIM insertion tool
Ultra-Slim case[/TD]
[TD]Redmi Note 5
Power adapter
USB cable
Warranty card, user guide
SIM insertion tool
[/TR]
[TR]
[TD="align: center"]SAR[/TD]
[TD]Head: 1.188 W/Kg
Body: 0.334 W/Kg[/TD]
[/TR]
[TR]
[TD="align: center"]Dimensions[/TD]
[TD]158.6 x 75.4 x 8.05 mm[/TD]
[TD]158.5 x 75.45 x 8.05 mm[/TD]
[/TR]
[TR]
[TD="align: center"]Weight[/TD]
[TD]181 gr[/TD]
[TD]180 gr[/TD]
[/TR]
[/TABLE]
Έρχεται επίσημα στις 16 Μαρτίου
Αναμένεται σύντομα να διατεθεί και στην Κινεζική αγορά -μετά το λανσάρισμά του στην Ινδία αρχικά-.
Η ανακοίνωση έγινε από τον Product Manager της Xiaomi στα -πλαίσια του MWC 2018- και σύμφωνα
με τα όσα ανέφερε το λανσάρισμα θα ξεκινήσει στις 16 Μαρτίου!​
Η συσκευή έχει ήδη περάσει από την ΤΕΝΑΑ (Κινεζική Επιτροπή Πιστοποίησης) και σε αυτές βλέπουμε
το Redmi Note 5 Pro (της Ινδίας), να παίρνει πιστοποίηση ως Redmi Note 5 - για την αγορά της Κίνας
προφανώς. Σύμφωνα με την καταχώρηση, το Redmi Note 5 θα διαθέτει FHD+ οθόνη 5,99 ιντσών, το
Snapdragon 636 SoC + Adreno 509 GPU στα ενδότερα, μαζί με 4GB RAM + 64GB αποθηκευτικού
χώρου, ενώ δεν αποκλείεται να δούμε και ακόμα πιο ισχυρή έκδοση με 6GB RAM!
Όλα δείχνουν οτι θα είναι το πρώτο μοντέλο της εταιρίας που θα βασίζεται στο Android 8.1 Oreo, ενώ
θα έχει διπλή κάμερα στα 12MP+8MP (σύμφωνα με την ΤΕΝΑΑ) και μία ακόμα selfie κάμερα μπροστά
στα 8MP, ενώ θα συνοδεύεται από μπαταρία 3900 mAh.
[via]
