Exact Audio Copy Νέα έκδοση 1.0 beta 1, Nov 23
paidi
27 April 2010
35
Νέα έκδοση για το καλύτερο πρόγραμμα Cd copy μετά από πολύ καιρό.
Version history:
November 23, 2010
Finally here is the new version 1.0 beta 1 which has some mighty new features. I took some time (mainly the complete change to unicode character set), but alls well that ends well…
Here comes a list of the new features:
+ Unicode support for all fields (but not CD-Text)
+ New database engine for storing CD information (old databases can be imported)
+ Metadata plugin support, for now there is a freedb plugin included. This will be released as open source freeware soon.
+ Cover support, can be drag’n'dropped from a file, a web page oder can be retrieved via a metadata plugin (support included in the freedb plugin). Cover can be written into tags or in the extraction directory
+ AccurateRip v2 support
+ Better Windows 7 support (like progress display in taskbar icon, storage of user data in the correct folders, etc.)
+ Free selection of first track track number (including option to continue numbering from the last inserted CD)
+ Option to always write the log file in english language
+ Option for writing a checksum over the extraction log data to the log file
+ Average extraction speed is listed in the log file
+ Possibility to write only V2 tags (and no V1 tags)
+ Free choice of replacement characters for filenames
+ Range copy selects now the first selected consecutive range of tracks as default
+ New folder browser dialog (system dialog for folders)
+ Added two placeholders for filename creation for track length (min and sec)
+ Test for (command line) compression options (and display of a sample command line)
+ Menu for removing unwanted/doubled spaces from “cd title”, “artist” & “track titles”
And some features are now removed:
- Removed Windows 2000 support (and any older OSs)
- Removed ID3V1 tag editor
- Removed compression offset
Hope you like it!
The next version is also planned, it will mainly contain an additional demo for a commercial metadata provider (if anybody would like to have access)
http://download.pcwelt.de/area_release/files/4A/60/4A603C8E579A96BA457DA34AB3D9FE57/eac-1.0beta1.exe
...το οτι ειναι beta υπάρχει περίπτωση να διμιουργήσει θεματάκια;;
Το δοκίμασε κανείς;
Πολύ "σετάρισμα" θέλει όμως βρε παιδί μου...
