Kosh
Fujifilm XF 400mm f/4.5: 609mm Reach at 2.74 lbs | Fstoppers
Fujifilm's new XF 400mm f/4.5 delivers 609mm full-frame equivalent reach in just 2.74 lbs with 5.5 stops of stabilization, linear autofocus, and weather sealing. Designed for wildlife, bird, and sports work.
fstoppers.com
FUJIFILM XF 400mm f/4.5 R LM OIS WR Lens - Newsshooter
FUJIFILM has announced its new XF 400mm f/4.5 R LM OIS WR Lens that was designed for wildlife, sports, etc. It is being touted as a lightweight super telephoto prime lens with a constant f/4.5 aperture. The lens weighs in at 2.74 lb / 1.24 kg and is 9.4″ / 239.5 mm in length. According to...
www.newsshooter.com
Key features
- APS-C | f/4.5 to f/22
- 600mm (Full-Frame Equivalent)
- Lightweight Super-Telephoto Prime
- High-Speed Linear Autofocus Motor
- Optical Image Stabilization
- Four ED and Two Super ED Elements
- Rounded 9-Blade Diaphragm
- Weather-Resistant Construction
