Ferguson HF 8900 HD - PVR Ready
AlexT_
10,461
Ferguson HF 8900 HD PVR Ready
Μια ακόμα αξιόλογη επιλογή τίθεται στη διάθεση μας. Ο διάδοχος του 8800 είναι PVR Ready δίνοντας μας τη δυνατότητα εγγραφής σε εξωτερικό σκληρό δίσκο.
Με τον προκάτοχο υπήρχε η δυνατότητα χρήσης εναλλακτικού-ανεπίσημου λογισμικού με διευρυμένες δυνατότητες αποκωδικοποίησης. Προφανώς τα ίδια θα ισχύουν και για αυτόν.
Τα χαρακτηριστικά του:
  • personal video recorder Mpeg-2/Mpeg-4 HD (H.264/AVC)
  • DVB-S2 digital satellite tuner built for digital Tv and radio channels in clear and scrambled standard or high definition TV (1920x1080)
  • 2 Common Interface Slots for CAM modules
  • 1 CAS for smart card
  • 1080i, 720p, 576p and 576i output format selection
  • upscaling up to 1920x1080 of the standard definition digital TV channels
  • TV screen format selection 16:9/4:3
  • recording, reproduction, deleting, fast forward, replay, pause/stop image, immediate research of sequences, file management, etc.
  • automatic recording of the digital satellite radios on the hard disk and its files management
  • OTR function (One Touch Recorder) with timer that can be programmed
  • multilanguage menus OSD, complete of EPG (Electronic Guide of the Programs)
  • Teletext with automatic memorization and quick selection of the pages
  • Timer complete of Sleep function and events programming (single, daily, weekly)
  • IF input for coaxial cable and Loop Out output for an external satellite receiver
  • HDMI, Component, Video Composite, 2 SCART outputs
  • SP/DIF Dolby Digital AC3 output
  • USB 2.0 and RS232 ports for the connection to a computer in order to update the PVR (settings, firmware, ect.)
  • 2 USB 2.0 Direct Access ports for the direct access, the transfer and the exchange, in input and in output, of the files (audio, video, data, etc) between the PVR and the computer and for using the PVR’s hard disk as second computer’s hard disk
  • DiSEqC Control 1.0, 1.2 & USALS supported
