FULL HD PROJECTOR Mitsubishi HC5000
Citation: Projection system: transmissive LCD
Panel specifications
Panel size: 0.7 " LCD, ratio 16:9 aspect
NUMBER OF of pixel: 1920x1080 (D6)
Driving method: LCD shutter array (x3, R/G/B)
Arrangement: Stripe arrangement
Optical specifications
Zoom shot/focus: Motorized
Optical axis SHIFTs: Motorized (vertically 75% and horizontal 5%)
f (mm): 24 - 38 mm
Light SOURCE lamp: 160W
Optical system: Prism synthesis system
Projection screen size (inch): 50-250
Projected image
Luminance (lm): 1000
Contrast ratio: 10000:1
Resolution, PC input: VGA 640x480, 1080p (1920x1080)
Scanning - horizontal (kHz): 15 - 100
Frequency - vertical (cycles per second): 50-120
Input signal system
Video: NTSC, NTSC4.43, PAL (including PAL-M and N), SECAM, PAL-60, Component video (480i/p, 576i/p, 1080i/p, 720p)
PC: PC/AT compatible, MAC, PC98
Input
Video
Similar to RGB: mini D-Sub 15 pin (1 connector)
Digitally RGB: HDMI/DVI (HDMI 1 connector, DVI-D 1 connector)
Composite: RCA terminal (1 connector)
S-video terminal (1 connector)
Component: RCA terminal (1 connector; color difference signal CAN input ton of D-SUB)
Serial/RS-232C standard: 1 connector (D-sub 9-pin)
Functions/others
Key clay/tone adjustment: V key clay/tone; H key clay/tone
Power volume-meets: 100 V AC 50/60 cycles per second
Power consumption (W): 280
Weight (kg): 5.0
EXternal dimension (WxHxD): 334x126.5x355 (excluding protrusions and legs)
Lamp running time: Eco mode 5000 h; normally 3000 h
Others
Accessories: Power cord (2,9 m), power plug adaptor, remote control, RGB signal cable, RS-232C cable, lens cap
attachment.php
κι ενα review.
http://www.cine4home.de/tests/projektoren/MitsubishiHC5000/HC5000Test.htm
Καποιες φωτο απο την υλοποιηση της mitsubishi οσον αφορα την δυναμικη ιριδα του μηχανηματος
:operator:
