Future-proof receiver
nektar
4 January 2007
4,326
Μελίσσια
Επειδή βλέπω πολλοί εδώ μέσα έχουν απορίες σχετικά με το τι ενισχυτή να αγοράσουν ώστε να μην χρειαστεί να ξανακάνουν σύντομα αναβάθμιση για χάρη των νέων format, βρήκα αυτό το ενδιαφέρον άρθρο στο avsforum. Ας το σχολιάσουμε.... :antlers:
http://www.avsforum.com/avs-vb/showthread.php?t=738511
Να βάλω εδώ και το ζουμί της υπόθεσης...(βέβαια δεν βλέπω να γίνεται αναφορά σε htpc, αλλά ας θεωρήσουμε ότι κατατάσσεται στις λύσεις με αναλογική σύνδεση - και ψηφιακή βεβαίως βεβαίως)
Levels of Receivers:
Level 1
5.1 receivers that provide SPDIF, 5.1 analog input channels and provide all three processing stages on digital sources.
Examples: Virtually all 5.1 receivers.
Level 2
7.1 receivers that provide SPDIF, 5.1 analog inputs, and provide all three processing stages on digital sources.
Level 3
7.1 receivers that provide SPDIF, 5.1 analog inputs, and 5.1 HDMI PCM but can't perform surround processing on PCM digital sources.
Examples: Panasonic XR57 (no processing at all).
Level 3.5 (added late in the game)
7.1 receivers that provide SPDIF, 7.1 analog inputs, and 5.1 HDMI PCM but can't perform surround processing on PCM digital sources.
Examples: Onkyo x04 series.
Level 4
7.1 receivers that provide SPDIF, 5.1/7.1 analog inputs, and 7.1 HDMI PCM but can't perform surround processing on PCM digital sources.
Examples: Panasonic XR700 (no processing at all). Onkyo 605. Sony STR-DG810 and higher.
Level 5
7.1 recievers that provide SPDIF, 5.1/7.1 analog inputs, 5.1 HDMI PCM, and allow all three processing types on all digital signals.
Examples: HK 645 and higher. Marantz SR6001 and higher (only with latest firmware?).
Level 6
7.1 receivers that provide SPDIF, 5.1/7.1 analog inputs, 7.1 HDMI PCM, and allow all three processing types on all digital signals.
Examples: All HDMI Denons. Yamaha RX-V661/HTR-6060 and higher. Pioneer Elite 81TXV and higher. Onkyo 705 and higher. Integra *.8 series.
Future-proof decisions:
If you don't care about 7.1 surround sound, then all receivers are future proof.
If you don't care about 7.1 surround sound for post-HDMI Dolby and DTS formats, or using generally inferior DACs in your player for post-HDMI Dolby and DTS formats, then receivers Level 2 and higher are future proof.
If you don't care about 7.1 audio for post-HDMI Dolby and DTS formats, then receivers Level 3 and higher are future proof.
If you don't care about 7.1 audio for 5.1 post-HDMI Dolby and DTS formats, then receivers Level 4 and higher are future proof.
If you don't care about being at the mercy of the generally inferior DACs in your player (vs the DACs in your receiver) for 7.1 audio and switching between HDMI and Analog output for 5.1 and 7.1 sources, then receivers Level 5 and higher are future proof.
If you want a true future proof receiver with full processing on post-HDMI Dolby and DTS formats, and true digital 7.1 channel support, then Level 6 receivers are future proof (see annotation).
oπως μου ειπε ο γεματουλης αμερικανος παντα θα βγαινει κατι καλυτερο και θα τρεχουμε εμεις να παραγγελνουμε τσιπ και ο κοσμος να τρεχει να αγοραζει το καινουργιο
ετσι και μεις θα βγαλουμε ενα φτηνιαρη με τα νεα φορμα το φεβρουαρη και ενα ακριβο τον ιουνη
ταδε εφη mr sunfire
Νομίζω πως δεν είναι ακριβώς έτσι.
Πρώτον, το πρώτο συμπέρασμα θα έπρεπε να λέει "If you don't care about surround sound...", όχι συγκεκριμένα 7.1. Αν κάποιος ενδιαφέρεται να ακούσει τα lossless formats TrueHD ή DTS-MA σε 5.1, θα πρέπει να συμβιβαστεί με τα "generally inferior DACS in your player" ή να πάει σε level 3.
Επίσης, υπάρχει και το θέμα του switching. Αν έχουμε περισσότερες από μία hdmi πηγές, θα πρέπει να κοιτάξουμε από level 3 και πάνω, και επιπλέον να αξιολογήσουμε το πλήθος των εισόδων και εξόδων.
