GeForce 8800 η πρώτη DirectX 10 κάρτα μέσα στο 2006!
Δεβελέκος Στράτος
1,626
Media reports from Taiwanese press suggest that Nvidia Corp. may release its next-generation flagship offering code-named G80 as early as in later in 2006. The information about possible release timeframe of the product which is likely to be named GeForce 8800 coincides with earlier rumours, however, the demand for the part may be limited due to the lack of DirectX 10.
A news-story at DigiTimes web-site claims that Nvidia may announce its code-named G80 processor, which official name is likely to be GeForce 8800, in mid-November to solidify its positions in the market of high-end computer graphics boards. The report cites makers of graphics cards as sources of the information, however, without bringing any details concerning the G80 technology or products on its base.
While not a lot of details are available concerning the GeForce 8800, it is known that the part is compatible with Microsoft’s next-generation DirectX 10 application programming interface (API), which will only be available with Windows Vista operating system. Nevertheless, provided that Nvidia launches mature drivers for the new graphics processing unit (GPU), the code-named G80 should deliver performance increases in modern games that use DirectX 9.0 API.
Last week pictures of the alleged GeForce 8800 emerged on the web. If the photos display what they claim to show, then the GeForce 8800 graphics card is about the size of the GeForce 7900 GX2, at least, it seems to be longer than the GeForce 7900 GTX, which means that it may not be possible to install it into smaller computer cases. The pictures also showcase that the new GeForce 8800 has 12 memory chips and a liquid-cooling option.
Specifications of the G80 chip are not clear. Some sources indicate that Nvidia’s first DirectX 10 chip will incorporate 48 pixel shader processors and an unknown number of vertex shader/geometry shader processors. Other, however, claims that the G80 has 32 pixel and 16 vertex and geometry shader processors. Yet another source has indicated that the G80 will have unified shader architecture and will consist of 700 million transistors.
xbitlabs.com
Οι DX10 κάρτες θα λειτουργούν ώς τέτοιες ΜΟΝΟΝ στα Vista. Στα XP κτλ. ώς DX9. Έως να μπούν τα Vista στήν αγορά δυνατά και να βγούν παιχνίδια και γενικότερα προγράμματα με DX10 έχουμε καιρό ακόμη. Περισσότερο είναι κίνηση επίδειξης απο την Nvidia παρά εμπορική επίθεση.
Re: Απάντηση: GeForce 8800 η πρώτη DirectX 10 κάρτα μέσα στο 2006!
Έφτασαν τα πρώτα κομμάτια Eυρώπη, παντου εξαφανίζονται ως δια μαγείας:
http://www.comtech.de/advanced_sear...ss=ab5543d066b307857d29c05145fa8ad0&x=17&y=12
Άντε να πέσουν τώρα και οι τιμές μπας και ψωνίσουμε τίποτα...
Πω, πω, ρε τί είστε σεις! Περιμένετε ρε να κυκλοφορήσουνε πρώτα τα Windows Σβήστα. :D
Μην πιστεύετε το website του Πλαισίου. Την αγόρασα από το κατάστημα τους στη Στουρνάρη την Πέμπτη και σκοτώνει κυρολεκτικά. Βέβαια είναι λίγο ...αλμυρή στην τιμή αλλά είναι πολλές φορές ταχύτερη από τη δεύτερη. Πρωτόγνωρα γραφικά και ταχύτητες ακόμα και με το παλιό DX9. Φαντάζομαι τι θα δούμε όταν κυκλοφορήσει και το DX10...
Σωστός ο φίλος Mach πήγα να πάρω και εγώ το Σάββατο μια 8800 αυτήν εδώ που την είχαν (την είδα με τα μάτια μου) στο κατάστημα τους στην Καλλιθέα:
http://www.plaisio.gr/product.aspx?catalog=1&category=26174053&product=903604
αλλά μου είπαν(έχω έναν γνωστό εκεί μέσα να περιμένω 1-2 μέρες για αυτήν εδώ που είναι η ίδια αλλά 60 Ευρώ φτηνότερη):
http://www.plaisio.gr/product.aspx?catalog=1&category=26174053&product=905755
Θα την χτυπήσω αλύπητα!!!!
οι ανακλήσεις ολοκληρώθηκαν πριν διατεθεί το προιόν στην αγορά , οπότε τα νέα είναι μπαγιάτικα ...
Εγώ θα περιμένω για 8χχχ κάρτες με DDR4 , εκεί θα πάρουν άλλο ένα 20% επάνω οι επιδόσεις ...
