Greg Rogers JVC HD-750 review
takisot
Μέλος Δ.Σ.
29,250
Παλλήνη
Το πολυαναμενομενο review του Greg Rogers για τον JVC HD-750 (ή RS-20 στην Αμερικη), ανεβηκε στο συνδρομητικο website του Widescreen Review. Το review, ως συνηθως, ειναι υπεραναλυτικο σε σημειο κορεσμου και καλυπτει καθε παραμετρο της αποδοσης του προβολεα, ο οποιος μενει πολυ καιρο με τον reviewer (γι'αυτο και αργησε να εκδοθει).
Αυτο που δεν περιμενα για να ειμαι ειλικρινης, ειναι ο ενθουσιασμος του διασημου reviewer για τον νεο JVC, οχι διοτι το προιον δεν το αξιζει, αλλα γιατι συνηθως ειναι πολυ συγκρατημενος στις εκφρασεις του!
Σας παραθετω απλως τον επιλογο του review για να παρετε μια ιδεα..
"The JVC DLA-RS20U merits more than my usual end-of-review
summary. The holy grail of home theatre is to combine the best qualities
of the finest CRT front projectors with the advantages of modern
lamp-based projectors. The RS20 comes closer to that goal than any
projector before it.
As I watched many more films than I can discuss
here, I consistently found myself thinking that the movie had never
looked better
––including DVDs that I had watched many times on
CRT projectors.
The extraordinary native contrast ratio of this projector, and its
recent JVC brethren, is perhaps the most important technical
achievement thus far in the era of lamp-based front projection
. It produces
extraordinary black levels with higher-than-CRT brightness,
which in turn permits higher gamma levels, to render superb image
depth without sacrificing shadow contrast. The RS20 has no lampbased
equal in dark-to-moderately-bright scenes, and thanks to its
ability to effectively utilize a higher gamma, it holds its own in bright
scenes.
The RS20 is not yet that mythical “perfect projector” we dream
about. There are some motion improvements that need to be made,
and I highly recommend an external video processor to upconvert
DVD movies to 1080p24. It would also be fascinating to see if a really
high-end lens could further improve image sharpness, although that
would probably double the price of the projector. But as is, the RS20
produces a sharper image with better high-resolution definition than
the finest CRT projector, and yet it never looks edgy or digitally
processed like some fixed-pixel projectors. It will reveal (and sometimes
be unjustly blamed for) film transfer flaws or video compression
artifacts, but when properly calibrated it won’t exaggerate film grain
or add noise that isn’t in the source. The best high-definition film
transfers look more like film than they do on any other lamp-based
projector I’ve seen.
The new Color Management System provided the
missing colorimetric accuracy that makes the JVC DLA-RS20U ($7,495)
not only an incredible value, but also my reference projector."
http://www.widescreenreview.com
Ναι, αναφερεται μονο στο invert telecine του processor του προβολεα οταν δεχεται σημα 480i και θελει να το μετατρεψει σε 1080p24, κοινως αδιαφορο για εμας..
ο Rogers οπως φαινεται απο την αναφορα του σεβεται τους CRTτους οποιους αναφερει πολλες φορες για μετρο συγκρισης,συνεπως στα δικα μου ματια μπορω να τον πιστεψω.Δεν εχω δει τον 750 αλλα απ'αυτα που λεει ειναι κορυφη εικονας και σιγουρα αν εψαχνα τωρα προβολικο αυτο θαπρεπε να δω.
Ξεχασα να αναφερω τις τιμες των μετρησεων contrast που πηρε στην οθονη αναφορας του (87-inch wide, 16:9 Stewart Filmscreen Studiotek G3 screen):
Με το zoom στο minimum throw, ο JVC εδωσε 883 lumens και on/off contrast ratio στα 23,600:1 με την ιριδα ανοιχτη (0).
Με την ιριδα κλειστη (-15), η φωτεινοτητα επεσε στα 544 lumens και το contrast εκτοξευθηκε στα 36,900:1.
Τωρα με zoom στο maximum throw, ο JVC εδωσε 652 lumens και on/off contrast ratio στα 32.700:1 με την ιριδα ανοιχτη (0).
Με την ιριδα κλειστη (-15), η φωτεινοτητα επεσε στα 328 lumens και το contrast εκτοξευθηκε στην τιμη-ρεκορ των 44.000:1 !
Με την ιριδα κλειστη (-15) και την λαμπα στο High, ο JVC εδωσε φωτεινοτητα 459 lumens (ητοι 20.1 foot-Lamberts (fL) απο την συγκεκριμενη οθονη) ενα με την λαμπα στο low 319 lumens ητοι 14.0 fL και με κοντραστ 39,960:1.
Το Ansi contrast (η αχιλλειος πτερνα των Lcos/Sxrd) μετρηθηκε στα ιδια επιπεδα με τους προκατοχους του (290:1).
Αν και οχι με την ιδια οθονη αναφορας, ενδιαφερον ειναι ποσο κοντα ειναι αυτες οι μετρησεις σε εκεινες του Μανωλη Καστρουνη οι οποιες ειχαν δημοσιευτει στο review του HD-750 που ειχαμε κανει για τον ΗΧΟ:
" Το contrast ratio on/off full field μετρήθηκε στο 39.550:1 με την ίριδα κλειστή και το zoom στην θέση TELE και thn λάμπα στο eco mode. Σε καμια όμως περίπτωση το contrast ratio on/off δεν έπεσε κάτω από 28.000:1. Το Ansi Contrast μετρήθηκε στο 380:1 ενώ στον HD100 είχαμε μετρήσει 345:1. Η φωτεινότητά του μετρήθηκε στα 755 Ansi Lumens(Normal mode) ενώ καλιμπραρσμένος έπεσε στα 489 Lumens.(Τιμή που μετρήθηκε και το max contrast ratio on/off). "
A this, last year tm πες του Greg (εδω θα βγαλει κανα νεο μοντελο η JVC πάλι).
Σοβαρα παντως, δλδ ειναι καλό το μηχανάκι παιδιά;
:p
Και εν πάση περιπτώσει, τι να μας αυτός ο Craig Daniel-πως τον είπατε όταν είχαμε ''διαστημικό'' review προ εξαμήνου από reviewer-Α-Δ(ι)αμάντι :p
:p
Λες να είναι και να μην το έχουμε πάρει 'πρέφα' ακόμη?:flipout:
Ε τότε να τον δούμε... ίσως αξίζει.:worshippy:
και την προηγουμενη που την ειχα παρει εγω :D
(ειχα φαει τον στρατηγο στην στροφη)
Μάλλον δεν τα ξέρεις καλά...:D
Εγώ άλλαξα συνολικά 3 HD-1...:blush:
Επειδή δεν το δήλωνα? Εάν θυμάσαι ήμουν ο πρώτος στην Ευρώπη που τον παρουσίασε...
Λες να μου ξέφευγε?
:firstprize:
Απάντηση: Re: Greg Rogers JVC HD-750 review
Λες να μου ξέφευγε?:firstprize:
Μη μιλάς γιατί θα μιλήσω...
Ο πρώτος HD1 που ήρθε στην Ευρώπη ήταν αυτός που είδαμε στο Intercontinental.
Κι ο πρώτος HD1 που ήρθε στην Ελλάδα ήταν αυτός που "παρέλαβε" ο Τάσος από την JVC τον είδαμε στο Panic Room και τον είδαμε και στο σπίτι μου (παρέα ήταν και ο Ντίνος).
Μετά τον πήραν και κάποιοι άλλοι αλλά δεν τους πολυθυμάμαι....
Μπίκο, βγες μία στο μπαλκόνι να κάνεις ένα τσιγάρο να ηρεμήσεις :p
ΥΓ Η ιεραρχία έχει ως εξής (για να μην τσακώνεστε ποιος την έχει μεγαλύτερη): Μπίκος > Κούλης > ΠαπαGeorge > All (εβαλα τον Κώστα μετά τον Κούλη για να σπείρω την Διχόνoια (Asterix tm)) :p
Edit
Ο Ντίμης είναι ακόμα μικρός και εκτός συναγωνισμού (μιας και ''η καρδιά του είναι αλλού'' tm) :p
Re: Απάντηση: Re: Greg Rogers JVC HD-750 review
Μπαμπίκο μου περνάν τα χρόνια και αρχίζεις να μην θυμάσαι....:flipout:
Ο 1ος JVC που ήρθε στην Ελλάδα, ήταν κατευθείαν από την JVC Japan και τον παρέλαβα εγώ από το περιοδικό Ήχος & Εικόνα!!!:grinning-smiley-043
Μάλιστα ήταν preproduction model... Δες ημερομηνία review...:silly:
Τότε είχε γίνει κεκλισμένων των θυρών...
Μετά το πέρας τον κράτησα εγώ μέχρι που ήρθε ο δικός μου...
Αν εννοείς 'αγοραστικά' ότι δεν είχα την πρωτιά... τότε πάω πάσο... έχεις δίκιο.
Εξάλλου πως μπορώ να αντικρούσω έναν Στρατηγό?:worshippy:
Edit
Καλά εσύ είσαι εκτός τόπου και χρόνου... :Banane0:
Και αυτός ο Κούλης δεν σε ενημερώνει άγκαιρα ρε παιδί μου...:flipout::flipout::flipout:
Απάντηση: Re: Απάντηση: Re: Greg Rogers JVC HD-750 review
Το γαμ...ένο το Αλτσχάϊμερ θερίζει.... :bang:
Ποιά JVC Japan μου λές; Από Αγγλία ήρθε και πήγε ο Τάσος στην Κηφησσιά και τον παρέλαβε... Θα μας τρελάνεις τώρα;
E καλα τωρα.
Ας πουμε για τον πρωτο που ηρθε στην Ελλαδα και πληρωθηκε !!! Για τα demo μιλαμε τοση ωρα ?? :lollypop:
