Hardware επιτάχυνση σε H.264, VC-1 and MPEG-2 HD απο την Nvidia
Δεβελέκος Στράτος
1,626
Πρώτη η NVidia παρεχει αυτην την δυνατοτητα που για να εκμεταλλευση απαιτειται η εγκατασταση των BETA driver 92.91 http://www.nzone.com/object/nzone_downloads_purevideo_32bit_92.91.html και φυσικά μια HDCP vga απο τις
GeForce 7950 GX2
GeForce 7950 GT
GeForce 7900 GT
GeForce 7900 GS
GeForce 7600 GT
Επισης δημιουργηθηκε ενα link με τις απαιτησεις σε hardware για να είναι εφικτή η αναπαραγωγη HD format! http://www.nzone.com/object/nzone_pvhd_build.html (A dual-core CPU with 1GB of RAM is recommended! )
Και τελος μια ενδιαφερουσα συνεντευξη του Scott Vouri (NVIDIA GM Multimedia) http://enthusiast.hardocp.com/article.html?art=MTE2NiwxLCxoZW50aHVzaWFzdA==
In order to play protected content like HD DVD or Blu-ray movies you need:
An HD DVD or Blu-ray disc drive with AACS and other content protection mechanisms installed. There are some older drives that do not have the content protection circuitry, so it’s important to check for this.
• AACS certified movie player software capable of playing Blu-ray or HD DVD movies. Initially player providers such as CyberLink and InterVideo will offer separate versions for Blu-ray and HD DVD movies. Today’s CPUs cannot decode the most demanding H.264 encoded Blu-ray or HD DVD movies on their own, so it is important to buy movie player software that takes full advantage of hardware accelerated decoding technology, such as PureVideo HD.
• A graphics card that has High-Bandwidth Digital Content Protection (HDCP) circuitry implemented on-board and provides hardware accelerated decoding of HD DVD and Blu-ray movies. You will also need an upcoming version of our ForceWare graphics driver that supports PureVideo HD to provide content protection and hardware accelerated decoding.
• A monitor or television that also supports HDCP
