HD2600 X2 DUAL GPU CARD by Sapphire
Browser
10,573
SAPPHIRE INTRODUCES HD2600 X2 DUAL GPU CARD
SAPPHIRE Technology – the leading manufacturer of AMD/ATI based graphics solutions is now introducing a new DUAL graphics accelerator based on the HD2600 XT.
SAPPHIRE’s HD2600 X2 can be configured with memory options of 512MB or 1GB of GDDR3 memory clocked at 800MHz (1600MHz effective) and each GPU core is clocked at 800MHz. Development is complete and the card is available now to order by OEMs and to integrators building special projects requiring multiple display configurations. Retail availability will be planned according to regional demand.
The new HD2600 X2 has four Dual Link DVI outputs that can be used to drive four separate high resolution displays at up to 2560 x 1600, or with CrossFireTM enabled will drive a single display with considerably enhanced performance. It is HDCP ready and has TV Output compatible with the latest High Definition displays. Like other HD2600 series products it also supports HDMI over the DVI interface with the correct HDMI Adapter.
The card is physically slightly taller than the standard ATX format. The HD2600 X2 is compatible with platforms based on AMD 580X Crossfire, AMD CrossFire Express 3200, Intel 975X Express, Intel P965 Express and Intel P35 Express motherboard chipsets.
All SAPPHIRE's current graphics cards are Microsoft Windows Vista™ ready and supported by the ATI Catalyst® suite of software, ensuring customers have easy and ongoing access to software updates for performance, stability and added features.
All trademarks acknowledged.
Editors – for further information please contact Bill Donnelly, Global PR Director, SAPPHIRE Technology – [email protected]
http://www.sapphiretech.com/us/
:grinning-smiley-043:grinning-smiley-043
Αυτού του τύπου οι υλοποιήσεις ήταν πάντα για τα μάτια του κόσμου και πρακτικά άνευ ουσίας.
Και αυτό γιατί οι επιδόσεις τους ήταν συνήθως προβληματικές λόγω μη δυνατότητας των οδηγών να αποδώσουν / χρησιμοποιήσουν παντού τον 2ο πυρήνα ενώ η τιμή τους συνήθως προσεγγίζει το μεγαλύτερο μοντέλο το οποίο παίζει καλύτερα και το βασικότερο, παντού (ανεξαρτήτως οδηγών).
Αυτο που θα μου αρεσε εμενα , και γιαυτο την εβαλα σε αυτην την κατηγορια, ειναι να δουλευει κανονικα με δυο οθονες ταυτοχρονα ισως και με διαφορετικες αναλυσεις. Γλυτωνεις σπλιτερ/σουιτσερ και ειναι καλο !!!!
Λογικά αν απλό crossfire είναι (απλώς στην ίδια πλακέτα) οπότε ότι ισχύει εκεί θα ισχύει και εδώ.
