Hdmi 1.4 3D spliτter matrix 6X2 (audio ARC & EDID )
Status
Not open for further replies.
svellinis
1 January 2008
1,850
Νομος Αττικης
Ενα hdmi 1.4a splitter υποστηριζει 3d με 2 hdmi εξοδους 6 hdmi εισοδους και μια οπτικη ινα με υποστηριξη
Audio Return Channel και επιλογη Audio EDID σε στερεο , 5.1 και 7.1 καναλια . Το δινω γιατι πηρα καινουργιο ενισχυτη και δεν το χρειαζομαι πλεον 90 Ευρω 6937306752
Compliant with HDMI 1.4a, CTS 1.4a, DVI 1.0; HDMI 1.4 support: Audio Return Channel(ARC), 3D TV Support, CEC 1.4
Supports 3D Video & 4KX2K, 8,10,12 & 16 bits per color depth; Support deep color up to 48bit per pixel
Supports MHL input, Share your smart phone photos, music and movies on the TV; Support Picture-in-picture (PIP) display function
Audio support: HDMI 1.4 compatible audio interface Dolby True HD DTS-HD Master Audio 7.1CH;Toslink digital audio port for great sound quality and surround audio
Built-in IR sensor with remote control for convenience; Simple and easy one-key switching;Metal case for quick heat dissipation and durable construction for longevity
Bandwidth: 2.97Gbps
Input: 6x HDMI, 5V/2A power (10W max.)
Output: 2x HDMI, 1x Toslink, 1x 3.5mm AUX
HDMI audio output: PCM2, 7.1CH, Dolby Digital 5.1, DTS 5.1, Dolby TrueHD, DTS-HD
Dimensions: 250 x 110 x 26 mm, Weight: 720g
Status
