hdmi splitter ή switch
klamia71
5 November 2007
2,956
ψαχνω splitter η swither με 2 η παραπανω εισοδους και 2 εξοδους για tv και προβολεα.
με ενδιαφερει να υποστηριζει καλα τα 24p. και να ειναι καλης ποιοτητας χωρις να πρεπει να δωσω τα λεφτα που κανει μια καινουργια τηλεοραση
σε normal επιπεδο τιμης βρηκα αυτa
1.... http://www.amazon.de/König-HDMI-Mat...ef=sr_1_4?ie=UTF8&qid=1292063684&sr=8-4-spell
2....http://www.amazon.de/Viforo-Matrix-Splitter-Umschalter-Adapter/dp/B0038KJ57I/ref=pd_cp_ce_3
3....http://www.amazon.de/Video-Matrix-S...ndbreite-225MHz/dp/B003D8M40U/ref=pd_sim_ce_7
εχει κανεις αποποψη γιαυτο ηα καποια αλλη καλη αξιοπιστη και δοκιμασμενη προταση/.?
Re: hdmi splitter η swither
ψαχνοντας βρηκα αυτο που απο χαρακτηριτικα ειναι σουπερ και 24p και τιμι μεσα σε λογικα πλαισια....
4x2 HDMI Switch Splitter - INFINIUS
From HD Cable
Price: £71.99
Availability: Usually dispatched within 1-2 business days
Dispatched from and sold by HD Cable
Average customer review:
Product Description
infinius HDMI Synchronised Switcher-Splitter Key features SKU: YKSWSP432 4 HDMI inputs / 2 HDMI outputs Synchronised outputs HDMI (V.1.3 with Deep Colour) device support Dimensions (W: 245mm H: 27mm D: 108mm) Eyefix signal compensation & correction technology 24fps & 100Hz device support 24K gold input connectors for maximum signal transfer corrosion resistance Full HD 1080p 48-bit deep colour resolutions supported Full support for DTS-HD Master Audio & Dolby TrueHD Audio HDMI pass-through HDCP pass-through USB firmware updateable Metal casing Mirrored front panel Simple plug & play operation UK 5v Power Supply included Slim line Remote Control (IR) included Lifetime Warranty This unit works with... Blu-ray Players Playstation 3 (PS3) & Xbox 360 Elite HDMI Supported Laptops & PCs Satellite HD Receivers HDTVs, Projectors & Displays Infinius is our elite range of HDMI switcher-splitter units. eyefix technology actively improves the HDMI signal integrity as it passes through the switcher chipset. Engineered with the most demanding and challenging set ups in mind, infiniu
Product Details
Brand: HD Cable
Features
Key features
Customer Reviews
Good bit of kit
I have both a hi def TV and projector (17 metre cable run) and needed to be able to link my sky Hi Def box (just upgraded and now with extra channels is well worth the money - the sky box upscaling of non hd output also improves most channels picture) and DVD to both displays without unplugging and plugging leads every time. The solutions seemed to be either to buy a new amp with 2 HDMI outputs at over £1200 or the splitter box. Since sky does not output its surround sound via the hdmi cables there did not seem much point in buying a new amp. The splitter box works well without any apparent loss of signal (even over the 17 meter cable run) and sits neatly next to my sky box and dvd. The only downside is that you have another remote to change between the 4 input channels (its small and easily lost so it sits on the splitter box when not in use)but this is no real hardship. Well worth the money.
Απάντηση: Re: hdmi splitter η swither
νομιζω πως αυτο δεν κλειδωνει στα 24p.
Κάνεις λάθος. Το μηχανάκι δεν επεξεργάζεται το σήμα, απλώς το περνάει. (pass trough) Συνεπώς δεν κλειδώνει οπουδήποτε. Χρησιμοποιήθηκε σε 1080p τηλεόραση και 1080p προβολέα χωρίς το παραμικρό πρόβλημα.
