Hi End Mac Pro
Status
Not open for further replies.
gekat2
7 November 2006
203
Λόγω αλλαγής αναγκών,πωλείται κορυφαίο σύστημα Mac Pro αποτελούμενο από:
- Mac Pro Dual Quad Core 2.8 (δύο Quad Core processors)
ATI Radeon HD 3870
2 GB Ram, 1 HD 320
- Apple Cinema Display 30"
Δεν τα λειτουργώ εδώ και ένα χρόνο και είναι βέβαια άριστα. Τιμές των αντίστοιχων καινούργιων είναι πλέον γύρω στις 6.000 ευρώ.
Τα δίνω περίπου στην μισή τιμή, 2.900 ευρώ.
Ανταλλαγές μόνο με μικρό αυτοκίνητο συν διαφορά.
Ανναλυτικά:
Processing
8-core: Two 2.8GHz, Quad-Core Intel Xeon 5400 series processors
Enhanced Intel Core microarchitecture
12MB of L2 cache per processor (each pair of cores shares 6MB)
128-bit SSE4 SIMD engine
64-bit data paths and registers
1600MHz, 64-bit dual independent frontside buses
Memory
800MHz DDR2 ECC fully buffered DIMM (FB-DIMM) memory
Eight FB-DIMM slots on two memory riser cards (four slots per card) supporting up to 32GB of main memory
256-bit-wide memory architecture
Graphics and displays
Double-wide, 16-lane PCI Express 2.0 graphics slot with one of the following graphics cards installed:
ATI Radeon HD 3870 with 512MB of memory and two dual-link DVI ports
Support for digital resolutions up to 2560 by 1600 pixels
Support for analog resolutions up to 2048 by 1536 pixels
DVI to VGA adapter included
Dual-display support for extended desktop and video mirroring modes
Communications
Two independent 10/100/1000BASE-T Ethernet (RJ-45) interfaces with support for jumbo frames
Bluetooth 2.0 + Enhanced Data Rate (EDR) up to 3Mb/s
Storage
Four 3.5-inch cable-free, direct-attach hard drive bays with built-in independent 3Gb/s Serial
16x SuperDrive with double-layer support (DVD±R DL/DVD±RW/CD-RW)
One open optical drive bay for optional second SuperDrive
Peripherals and audio
Two FireWire 800 ports (one on front panel, one on back panel)
Two FireWire 400 ports (one on front panel, one on back panel)
Five USB 2.0 ports (two on front panel, three on back panel)
Two USB 2.0 ports on included keyboard
Front-panel headphone minijack and speaker
Optical digital audio input and output TOSLINK ports
Analog stereo line-level input and output minijacks
PCI Express expansion7
Three open full-length PCI Express expansion slots
One PCI Express 2.0 x16 slot
Two PCI Express x4 slots
All slots provide mechanical support for 16-lane cards
300W combined maximum for all PCI Express slots
Size and weight
Height: 20.1 inches (51.1 cm)
Width: 8.1 inches (20.6 cm)
Depth: 18.7 inches (47.5 cm)
Weight (standard configuration): 42.4 pounds (19.2 kg)8
Υπάρχει περίπτωση να δωθούν ξεχωριστά οθόνη και tower?
Και αν ναι, σε τί τιμές?
Ευχαριστώ προκαταβολικά.
Θα προτιμούσα να τα δώσω μαζί.
Πες μου ποιό απ΄τα δυό σε ενδιαφέρει?
Πες μου ποιό απ´τα δυό σε ενδιαφέρει?
Ένας φίλος ενδιαφέρεται για το tower και εγώ θα ήθελα να ακούσω τιμούλα για την οθόνη.
Από την τιμούλα θα εξαρτηθεί αν θα ενδιαφερόμουν ή όχι να σου πώ την αλήθεια μου. Δεν ήμουν σε αναζήτηση αλλά αν είναι δελεαστική, θα το σκεφτόμουν.
κι εγω ενδιαφερομαι για την οθονη σκετη αλλα οντως, μονο αν ειναι καλη κ δελεαστικη η τιμη της.Δηλαδη αν την δωσεις κανα 900αρι (λεω τωρα τυχαια..) δε θα το σκεφτω.Αν γινει κατι καλυτερο..
Εχετε και οι δύο ΡΜ.
Τελικά γίνεται να δοθούν και χωριστά.
Το Mac Pro στα 1700
Η Apple cinema στα 900
Αν υπάρχει λογική πρόταση, στείλτε μου ΡΜ
Προσθέτω ένα 500άρι δίσκο ακόμα και η τιμή διαμορφώνεται στα 2400.
Super τιμή πιστεύω.
Status
