Η επιστροφή των KURO...10G προ των πυλών!!!
czoun
29 November 2007
7,724
Pioneer KURO 10G
Με
νέα τεχνικά χαρακτηριστικά , που εντυπωσιάζουν:
  • thinner (mm)
  • lighter weight (kg)
  • reduce power usage (kW)
  • reduce buzzing (dB)
  • reduce image retention
  • faster response times (ms)
  • better motion resolution (lines)
  • higher display resolution (1440p, 1600p, or 2160p)
  • higher pixel sample resolution (36 bits)
  • more accurate color (Rec. 709 and D65)
  • automatic video calibration with colorimeter sensor (gamma, color points)
  • faster channel changes
  • tru2way
  • display 3D video
  • integrated web browser
  • faster and smoother DLNA support
  • integrated VOD player (YouTube, Hulu, Netflix, Amazon, ...)
  • DVR support with external USB 2.0 hard drive
  • setenv $DISPLAY kuro:0 (for remote X11)
  • XDMCP support (be an X server)
  • network firmware updates
Με τον νέο επεξεργαστή FUGA , που υπόσχεται κορυφαία εικόνα:
Fuga features:
  • Enhanced Gradients
Enhance the contrast gradients of low quality and non-HD signals. Smooth the image with the goal of improving detail. It is unknown if this improvement involves the current pixel dithering done with the plasma panel since it was said that high quality signals pass through this new feature untouched.
  • Improved Color Saturation
Extract more detail and create a 3D color depth by intelligently improving color saturation. The color space and the range of black levels are not changed. Sort of like the Optimum AV mode but only for color and tint.
  • Smoother PureCinema algorithm
The PureCinema algorithm controls de-interlacing, 3:2 pulldown, interpolation smoothing, and 24p film mode. This new feature improves the Smooth PureCinema algorithm that interpolates the in-between images. Motion judder is improved, even with 1080p24 signals. The PureCinema smooth option is currently not available on 9G Kuro's with 1080p signal sources. These increased DSP calculations are possible because the Fuga processor has more vector analysis capability.
  • Depth of Field
Real-time ability to change a video image's depth of field. Focus or defocus the background and foreground elements. Very powerful. How or why this will be used is unknown.
Ημερομηνία κυκλοφορίας δεν έχει ανακοινωθεί, αλλά ως πιθανότερη είναι ο ΝΟΕΜΒΡΗΣ του 2010.... :party:
Όχι ρε γαμώτο πως θα περιμένουμε μέχρι τότε??????????
υ.γ. για το κέιμενο :SFGSFGSF:
Απάντηση: Re: Η επιστροφή των KURO...10G προ των πυλών!!!
LED θα εχουν? Για καλυτερο μαυρο και κινηση στα 24p...:flipout:
Με επεξεργαστή i7 ξεχωριστά για κάθε pixel. Οπότε μιλάμε για περίπου 2.073.600 επεξεργαστές για 1080p. Για τις μεγαλύτερες αναλύσεις θα υπάρχει ειδικό container έξω από το σπίτι που θα περιέχει την συστοιχεία των επεξεργαστών.
χαχα!
αν και τωρα που εφυγε η πρωταπριλια ισως θα επρεπε να αποσυρθει ή να επισημανθει το θρεντ;
ειναι καπως....:BDGBGDB55:
Πάντως, η απόσυρση της Pioneer από τα πλάσματα είναι μία από τις χαρακτηριστικές περιπτώσεις κατά τις οποίες η ανθρώπινη τεχνολογία οπισθοχώρησε πολλά βήματα πίσω!
βλέπε κατάργηση του Concord (χωρίς αντικατάσταση), βλέπε διακοπή επανδρωμένων αποστολών στη σελήνη (αν τελικά πήγαμε ποτέ), βλέπε .......
Δυστυχώς αυτά συμβαίνουν όταν η τεχνολογία δεν γίνει οικονομικά προσιτή (Concord) ή γίνεται χωρίς σκοπό (προσσελήνωση).
Όταν η κούρο είχαν 4-5 χιλιάρικα, πώς να πουλήσουν; Όταν έκλεισε το τμήμα, και κατέβηκε η τιμή στα 2,5 χιλιάρικα, ξεπούλησε...
