Ηχεία DALI BLUE SERIES 5000
takisot
Μέλος Δ.Σ.
30,141
Παλλήνη
Πωλειται το ακολουθο σετ ηχειων της γνωστης Δανεζικης Dali, λογω μετακομισης σε χρωμα cherry και αριστη κατασταση.
Left/Right Dali 5005
Blue Series 5005 is the bigger brother to 3003. Larger drive units and larger enclosure adds yet another dimension to the impressive sound that is a characteristic of the Blue Series. The appearance is at once bold and classic, resulting in the Blue Series 5005 blending into any environment. Twin 6.5” woofer/midrange units, 1” soft dome tweeter, DALI’s famous hand-assembled crossover network, biwiring and reversible spikes – they are all elements that position Blue Series 5005 in the audiophile hall of fame. Detailed sound, dynamics and a bass that is objective and possesses presence are just some of the words that are associated with Blue Series 5005.
DALI Blue Series 5005
Frequency Response, ±3dB 37 Hz - 25 kHz
Crossover Frequency 3.5 kHz
Sensitivity (2.83V/1m.) 91.5 dB
Nominal Impedance 4 Ohm
Maximum SPL 111 dB
Rec. Amplifier Power, 8 Ohm 25 - 150 Watts
High Frequency Driver 1"
Low Frequency Drivers 2 x 6.5"
Midrange Driver -
Enclosure Type Reflex, 36.5 Hz Tuning
Placement Floor
Recommended Rear Wall Distance 10 - 100 cm
4 - 40 in.
Dimensions (HxWxD) 86 x 21.5 x 29.4 cm
33.9 x 8.5 x 11.6 in.
Weight (kg/lb) 13.3/29.3
TIMH: 250 Euros (αγοραστηκαν 600 Euros)
