Info Onkyo TX-NR 807 + CantonMovie CD102
AdrianoS
12 December 2009
4
Athens
Ελάτε παιδιά, χρειάζομαι τη βοήθειά σας, και συγγνώμη που δεν γράφω καλά ελληνικά, είμαι ξένος και ζω στην Ελλάδα (Google Translate powered :p)
hi mate.in my point of view you are buying a very very good ampilfier but you connect him with a really low budget speaker system so he will not prove his point if you know what i mean.make it more balanced if you can. what is your budget buy the way??
My combination of 807 is
front : Klipsch RF-62 (black) Floorstanding-Speaker
center : Klipsch RC-52 (black) Center-Speaker
subwoofer : Klipsch RW-10D (black) Active-Subwoofer
about back speakers, still dont know which to choose ...
a) Klipsch RB-81 (black) Bookshelf-Speaker or
b) Klipsch RB-61 (black) Bookshelf-Speaker
Room is about 40m
Listen most Rock, dance, rnb and watch movies of course
If you listen classical, opera, etc look for b&w 684.. etc...
Thanks for your reply guys,
my budget is around 1000 euro, but due to my very small saloni, around 12 square meters, I Need small speakers, so I was considering 2+1 speakers set, but after changed my mind because not a Real Home Theater sound.
Basically I choosed the 807 due to the Ethernet card which could be Very useful to interconnect the PC, and of course for the sound quality of this Amplifier too, but for the speakers I dunno what to do, what do you think, better go with a good 2+1 and after step by step add the others speakers??? Suggest me please the best solution..
Thanks,
Adriano
