Ionic Tweeter
vas silis
26 May 2008
834
δεν ξέρω αν έχει ξανα συζητηθεί, αν δεν έχει για πείτε καμία γνώμη για αυτό.
ION TW 1S (Ionic Tweeter)
The ... ion tweeter Ion TW 1 S“ is a perfected and sophisticated loudspeaker chassis, whose exceptional performance and qualities can only be enjoyed completely if used properly.
It was designed to reproduce the harmonics of the music as detailed as possible. To reach this goal, a design with the smallest possible mass had to be developed. Relative to its function the Acapella ion tweeter has no mass! To carry out this project, a very unusual kind of design had to be created.
High voltage within the unit produces a constant arc. This arc is modulated with the musical signal (flame oscillates with the time of the music). This is the reason why the number of electrons within the arc varies. A larger or smaller amount of electrons requires similar space. Due to this variable need of space the surrounding air molecules have to dodge the more or less quickly. This evasive action or bumping of the air molecules generates over-, resp. underpressure and, therefore, sound. In this way, the .... ion tweeter is able to reproduce sound without membrane and without mass
Regarding transient capabilities and phase stiffness, the obtained sound quality cannot be realised by using conventional tweeters. Comparing the ion tweeter with other tweeter systems, its unobstrusive sound image will attract you. This kind of reproduction is to be attributed to the lack of harmonic and transient distortions.
Technical data
Sensitivity (aktive Tweeter): 1,5Volt / 0 dB
Impedance: 600 Ohm
Sound pressure level: max. 110 dB - 1 m / 1ms
Slope Input filter: approx. 12dB/octave
Frequency response: 5kHz - >50kHz (variable crossover frequencies )
Mains voltage: 234 Volt / 50 Hz Standard
Optional 110 -, 117 -, 227 Volt / 50 - 60 Hz
Dimensions H x W x D: 150 x 300 x 260 mm
Weight: 15 kg
Ναι ..ειχα φτιαξει ενα με την el519 tube ..Αλλα κατι δεν πηγαινε καλα .. μυριζε και ιονισμενο αεριο ..δεν θυμαμαι , θα το ψαξω ξανα..παντος ψιλοεπαιζε απο οτι θυμαμαι:guitarist:
όζον είναι το side effect , αυτό μυρίζει .. πόσο το έχει ο καλλιτέχνης ???
Για την τιμή δεν το έψαξα. Απλά ρωτάω αν μπορεί να θεωρηθεί ότι δίνει κάποιες λύσεις αν είναι «καλό», αν ξέρει κάποιος κάτι παραπάνω, γιατί όπως και να έχει είναι κάτι διαφορετικό.
ιοντων τουιτερ ... αυτο που ξερω ειναι της acapella και θεωρειται το καλυτερο τουιτερ που εχει υπαρξει ποτε ( νομιζω ότι τοποθετηται σε ηχεία της acpella ανω των 30.000,00 ευρώ.
P.S. Κε Μιχαήλο την γνώμη σας?
Απο οσο καταλαβα μονο αυτην χρησημοποιουν οι diy.Υπαρχει κανενας λογος?
Οχι μονο αυτην , ολες οι sweep tubes ταιριαζουν για αυτη την κατασταση λειτουργιας ,,οπως οι EL519 , EL504, 6KD6, 6LF6, 6GW6 , 6JN6 , κλπ , οπως και οι rf tubes 829 ,6146,8552, ..Απλα γιατι δεχονται ανετα υψηλη ταση 600+ VOLT, εχουν ισχυροποιημενη καθοδο για μεγαλο ρευμα [ειδικα οι sweep] ωστε να δημιουργηθει το corona effect [RF αυτοταλαντωτο] και το πιο σημαντικο το S του G2 ειναι μεγαλο [πυκνο πλεγμα] και διαμορφωνεται ευκολα απο το audio σημα,,:guitarist:
Έχω δει στο audioxpress κανα δυο κατασκευές.
Το acapella το είχαμε ακούσει πριν δυο ή τρία νομίζω χρόνια σε έκθεση και η γνώμη όλης της παρέας για τα πρίμα του ήταν ουαου!!!!
Για diy μου φαίνεται πολύ δύσκολο. Η acapella το έδινε από τότε χώρια σε λογική αν θυμάμαι τιμή.
Θέλει ανοιχτό παράθυρο αφού τέτοιος σπινθήρας κάτω από 20Khz παράγει όζον.
Δεν ξέρω τη γνώμη του κατασκευαστή για αυτό.
Πάντως είναι πολύ ενδιαφέρον
Μήπως είναι καλύτερα να χρησιμοποιείται μόνο ως σούπερ τουήτερ, για να μην παράγει όζον;
Δεν είναι κι ό,τι καλύτερο για την υγεία...
Με καλυψες:grinning-smiley-043:grinning-smiley-043:grinning-smiley-043
Οσο για το οζον παραγεται σε ολες τις συχνοτητες,ακομα και οταν ειναι ανοιχτο αλλα δεν βγαζει ηχο.Παραγεται απο την υπερυψηλη θερμοκρασια.Δεν εχει σχεση η συχνοτητα διαμορφωσης της σπιθας
Technical data
Impedance: 600 Ohm
Weight: 15 kg
..μπορεις να ριξεις και μια ματια στο site του Urlich, αλλα ειναι Γερμανικα.
http://www.plasmatweeter.de/
Aκριβως αλλα τοποθετειται και στο violon που κοστιζει λιγο, λιγοτερο. Ακουγεται υπεροχα και συνδυαζεται με την κορνα. Δεν παιζει αυτονομα τις υψηλες και ανεβαινει πολυ ψηλα...
Γιάννη, υπάρχουν οδηγίες από την εταιρεία σχετικά με το όζον που παράγει;
Ναι... Ενδείκνυται η χρήση των ηχείων στην Ανταρκτική και γενικά σε μέρη που θα κλείσει την τρύπα του όζοντος... :flipout:
