Irdeto Module Μωβ Αναβαθμιζεται?
DimAsi
25 July 2007
6,245
Αττικό βουνό
Υπάρχει τρόπος να αναβαθμιστει η irdeto η μωβ δορυφορικά μεσω feed η με αλλο τροπο ?
Ο λόγος ειναι οτι δεν μου παιζει την καρτα alJazeera ενω η κάρτα σκετη στο δεκτη παιζει και θελω να βαλω τη μοντουλα ωστε να απελευθερωσω τη μια slot
1. Minimum requirement
- Computer with a free PC-Card slot
- Microsoft Windows 2000 or XP
- 1MB free hard disk space
2. CAM insertion
Please insert your CAM (Conditionnal Access module) in the extender and please insert the extender in a
free PC-Card slot.
Note: Some laptops are able to detect CAM without extender. If when you insert the CAM without
extender, you get no windows message like “new device detected” or PCMCIA-MTD-002 plug and play
string, you need to use the extender. Two extenders are delivered in the package.
Note: Two version of extender are available. If the extender you got has a switch (see picture above),
please be sure that the switch is set on the left like on the picture.
SmarTools CAM Updater User’s Guide 3
3. Driver installation
After module insertion, windows should open this window. Please select “Setup from a list or a specific
location (advanced users). Then, next.
Warning: if your computer detects “PCMCIA-MTD-002”, you must use the CAM adapter.
Select “look for the best driver in those locations”. Please browse your computer to set the folder where
you have unzip the file downloaded from the web. Then next.
Your computer will search for a drivers.
SmarTools CAM Updater User’s Guide 4
When the driver has been found, you should get (only for Microsoft Windows XP users) this message.
Please select Continue.
Now, your driver is well setup. You can see your CAM in the task bar, by double-clicking on the green
arrow has shown below
You CAM is listed as Camtools.
SmarTools CAM Updater User’s Guide 5
4. Download process
Please launch downloader 2.0 application. The following window will be opened.
Open file selection and look for the folder where you have unzipped the file download on SmarDTV
website. Look for the file with “.out” extension, and then open it.
Now, you have to select the module you will download. Select the SCM DVB CA Module and OK.
SmarTools CAM Updater User’s Guide 6
Now, you can start your download. The download may take a few minute and never extract the module or
power down your computer until download is finished otherwise your CAM will not work anymore.
When the download is finished, you should get the message: “Download procedure successful > End of
transfer”. Now, you can extract your module and insert it your decoder.
Contact
Email
If you have any question or request about this document, please contact SmarDTV support team at
[email protected] or on the web at www.smardtv.com.
Έχω διαβάσει ότι αναβαθμίζεται σε laptop με συγκεκριμένα Windows κ.τ.λ
Ποια μωβ έχεις;
Δεν γραφει τιποτα μόνο irdeto μπροστα .Το θεμα ειναι ποιος και που μπορει να το κανει εφοσον δεν γινεται μεσω δορυφορου
Δώσε κάποιο link από την μοντούλα,να καταλάβουμε πια είναι.
Είχα πάρει μια τέτοια μοντούλα και είχα προβλήματα και την πήγα πίσω.
Δεν ξέρω κατα πόσο η αναβάθμιση της θα λύσει το πρόβλημα.
Το παλιό μπλε αναβαθμιζόταν (ως ενα σημειο) για το μωβ (που ειναι το νεότερο όλων) δεν έχει ακουστει να υπάρχει κάποια αναβάθμιση, είτε δορυφορικά είτε αλλιώς
το ιδιο προβλημα ειχα και εγω με την καρτα του aljazzera sports, ειχα την παλια μοντουλα την μπλε μου ανοιγε κανονικα την καρτα ,αλλα μολις εκανε η καρτα ανανεωσει κλειδιων μπλοκαρε και μαυριζε.το ιδιο και στο card reader του δεκτη.η καρτες kappa ειναι μα@@@@ παρε μια καινουρια μοντουλα irdeto μοβ την τελευταια που κυκλοφορει να ησυχασεις.το ιδιο ισχυει και για της viaccess της καινουριες καρτες οι παλιες μοντουλες οι κοκινες δεν ανοιγουν τιποτα.
Όπως τα λεει ο rangers72, η παλιά μπλε μοντούλα δεν κάνει για τις νεες κάρτες irdeto και δεν αναβαθμίζεται σε μωβ, χρειάζεται αγορά νέας μοντούλας
Μα ο φίλος έχει ήδη την μωβ!
Το πρόβλημα ποιο ακριβώς είναι; Δεν κάνει update ενώ στο UCAS κάνει update; Μόλις κάνει update στο UCAS, για πόση ώρα παίζει στο μωβ; Ή δεν παίζει καθόλου;
Απάντηση: Re: Irdeto Module Μωβ Αναβαθμιζεται?
Υπάρχουν πολλές μωβ μοντούλες ,η συγκεκριμένη μωβ δεν είναι από τις πιο αξιόπιστες.
Στο πρώτη μήνυμα του ο φίλος λέει ότι παίζει η κάρτα κατευθείαν στον δέκτη .
Πανο απευθειας στον AZBOX την καρτα του ALjazeera την παιζει .Τωρα αν τη βαλω στη μοντουλα τη μωβ δεν την παιζει καθολου!
greekgreek τοτε ποια μοντουλα παίζει την Aljazeera μως αν δεν την παιζει αυτη που εχω?
Re: Απάντηση: Re: Irdeto Module Μωβ Αναβαθμιζεται?
Μάλιστα, δεν παίζει καθόλου δηλαδή με το CI. Άλλη κάρτα irdeto παίζει στο CI με τον Azbox; Μήπως δηλαδή είναι ασυμβατότητα με το CI και όχι με την κάρτα. Η μόνη διαφορά της Al Jazeera κάρτας είναι ότι δηλώνεται σαν ACS 6.x και όχι ACS 5.x.
Δεν έχω την κάρτα(και δεν το έχω ψάξει) του Aljazeera για να σου πω με ποια μοντούλα παίζει.
Την μοντούλα που έχεις την αγόρασα και εγώ(πριν ένα -ενάμιση χρόνο) ,όταν την δοκίμασα είδα ότι υπήρχαν προβλήματα.
Έψαξα τότε να δω άν υπάρχουν αναφορές για την συγκεκριμένη μοντούλα ότι έχει προβλήματα με κάποιες κάρτες και βρήκα ότι υπήρχαν προβλήματάκια με την κάρτα της nova.
Tην επόμενη μέρα την πήγα πίσω και πήρα τα λεφτά μου πίσω.
Την εβαλα σε humax 5400 που εχω στον πατερα μου και παιζει την καρτα κανονικά οπως και την καρτα της NOBA ,μολις τις βαλω στην μοντουλα δεν τις βλέπει ουτε ο Humax
