JVC HD 750- Νεο firmware
takisot
30,706
Παλλήνη
Σε λιγο καιρο κυκλοφορει και επισημως το νεο firmware για τον JVC 750 το οποιο διορθωνει τα προβληματα του CMS που ειχαν αναφερθει.
Στην Αγγλια οπου εγινε το beta testing τα reports ειναι ιδιαιτερα ενθαρυντικα:
Calibration Results
attachment.php
I am happy to report after lots of testing and re-testing of the new software upgrade that the CMS system now works as it should and in a linear fashion.
As you can see the results, first of all for the greyscale, were almost completely perfect with just a slight red error around 60ire, but with DeltaE errors well under 2 across the board. This was an excellent result with Gamma hitting 2.2 as desired and D65 CCT hit correctly. After hour and hours of testing I just couldn’t improve any further our results here.
Moving to the Gamut and the CMS results, you can see that we managed to get all the points, along with luminance levels and DeltaE errors to within a whisker of perfection. This was the case across all the stimulus points showing that the previous issues with clipping and under saturation where now fixed. Plus, these results were repeatable by resetting the HD750 to factory defaults and calibrating six (read it, six) times, each run attaining near perfect results. And those of you who know how long it takes to fully calibrate a display will appreciate just how long I have spent fully testing this unit.
So after an initial false start with the HD750 and its CMS controls, I can happily report that all is now working as it should and the results are fantastic!
Περισσοτερα εδω:
http://www.avforums.com/reviews/index.php?reviewid=41
Οχι βεβαια! Αυτο ελειπε, να εμπαινε το firmware στον 350 και να ..αναβαθμιζοταν σε 750! :D
Απ ότι μαθαίνω ο 350 πετάει (καλά, δεν είναι και σαν τον 5000 του Γιώργου (ο οποίος μαθαίνω παίζει να κοντράρει και τον Sony τον 10αρη (ακόμα και χωρίς καλό καλώδιο ρεύματος ή αναμορφικό φακό)) αλλά προσπαθεί ο καημένος - 3 in 1 tm :p)
Πλακα πλάκα πάντως, αν δεν είχα δει την ουσιαστική διαφορά μαύρου μεταξύ 350-750 και όπως έχω ήδη πει, δεν θα μου έκανε μεγαλή εντύπωση η μόνη διαφορά των 2 μηχανημάτων (350-750) να ήταν το firmware.
Με βρήκες μικρό και με πειράζεις έεεε, καλά βρέ σύ δεν θα μεγαλώσω?, ...θα σου πώ εγώ! :flipout:
Άρα πρέπει να είναι σούπερ το μηχανάκι!!! Μπράβο...
Φιλικά
Γιώργος.
Υ.Γ. Κάποιο "πουλάκι" μου είπε ότι κάτι ...κατάπιαν τα ηχεία σου και <τσιρίζουν>! Δεν έρχεσαι κατά δώ να ακούσεις ολίγην λαμπίτσα να ζεσταθεί λιγουλάκι τ' αυτάκι σου??? :p
Εγω νηστευω αλλα εχω κατι ιδεες:flipout:
Εμ βέβαια, λείπει ο Μάρτης από την Σαρακοστή;
Οι 'αποπάνω' (συμπεριλαμβανομένου του πουλακίου-ποντικομαμής) θα λάβετε τις απαντήσεις σας εν ευθέτω χρόνο.
:p
O 350 με έχει αφήσει άφωνο! Πραγματικά τον απολαμβάνω και κάθε φορά που βλέπω έργο με κερδίζει ακόμα περισσότερο. Αν και είχα αρχικά τύψεις για τα χρήματα που έδωσα, αυτή τη στιγμή θα το έκανα με κλειστά μάτια. Έχω βάλει και 37 ώρες και έρχεται και η ώρα της ρύθμισης.
Αλλά πρέπει πρώτα να ασχοληθώ λίγο και με τις κουρτίνες...Τον έχουμε φτιάξει μονόπατα τον μαύρο τοίχο
Μπράβο φίλε μου, τουλάχιστον έπιασαν τόπο η υπομονή σου να τον περιμένεις τόσον καιρό, αλλά και τα ουκ ολίγα ευρώπουλα που έριξες!
Να τον χαίρεσαι και να τον απολαμβάνεις όσο πιό πολύ μπορείς! -bye-
Φιλικά
Γιώργος.
