Κάρτα γραφικών CGN-346TVD AGP/256 silent, 20 ευρά.
Status
Not open for further replies.
SHERPA
3,653
Βέροια
Ότι λέει ο τίτλος.
Εξοδα αποστολής 5 ευρά.
Αποστολή με κούριερ κατόπιν τραπεζικής κατάθεσης.
CGN-346TVD Product Overview
Technical Information
RAMDAC Speed: 400 MHz
Dual RAMDAC: Yes
Maximum Resolution: 2048 x 1536
Analog Signal: Yes
Digital Signal: Yes
API Supported: OpenGL
Processor & Chipset
Chipset Line: GeForce
Chipset Series: PCX
Chipset Model: 5300
Processor Speed: 250 MHz
Memory
Standard Memory: 256 MB
Memory Technology: DDR SDRAM
Bus Width: 128 bit
Interfaces/Ports
Host Interface: AGP 8x
VGA: Yes
Number of VGA Outputs: 1
Miscellaneous
Additional Information:
4 Pixel pipelines
VertexShaders: 2
NVIDIA Cinefx Shading Architecture:
Support for DX 9.0 pixel shader 2.0+
Support for DX 9.0 vertex shader 2.0+
Very long pixel programs up to 1024 instructions
Very long vertex programs with up to 256 static instructions and up to 65,536 instructions executed before termination
Looping and subroutines with up to 256 loops per vertex program
Subroutines in shader programs
Dynamic flow control
Conditional write masking
Conditional execution
Procedural shading
Full instruction set for vertex and pixel programs
Z-correct bump mapping
Hardware-accelerated shadow effects with shadow buffers
Two-sided stencil
Programmable matrix palette skinning
Keyframe animation
Custom lens effects: fish eye, wide angle, fresnel effects, water refraction
High-Performance 2d Rendering Engine:
Optimized for 32-bpp, 24-bpp, 16-bpp, 15-bpp and 8-bpp modes
True-color, 64�64 hardware cursor with alpha
Intellisample HCT:
Blistering-fast antialiasing performance
Adaptive texture filtering
Fast z-clear
NVIDIA Digital Vibrance Control (DVC) 3.0:
Image sharpening controls
Color controls
System Requirements:
Intel Pentium or AMD Athlon or compatible
128MB of system memory
Mainboard with free AGP 8x Slot
CD-ROM drive for software installation
350Watt or greater Power Supply
Compatibility:
Operating System Support:
Windows XP
Windows 2000
Windows Me
Windows 98
Windows 95
Linux
Platform Supported: PC
http://www.brokerbin.com/resellers/n...CGN346TVD.html
H κάρτα εδοκιμάσθει προχθέ και είναι αψογοτάτη:))
Status
