- 23 February 2007
- 269
Πωλειται η καρτα ηχου SOUND BLASTER AUDIGY 2 με την εξωτερικη της μοναδα, τηλεκοντρολ κι ολα τα καλωδια συνδεσεων που περιειχε η αρχικη συσκευασια
Δυστυχως πρεπει να την αποχωριστω μιας και πρεπει να ελευθερωσω μια θυρα PCI και αφου δεν εκμεταλλευομαι πια τα χαρακτηριστικα και την απιστευτη συνδεσιμοτητα της
Λεωνιδας 6972086325
Τιμη 35 ευρω
Technical Specifications
-High Definition Audio Quality for Playback & Recording
-24-bit Digital-to-Analog conversion during playback with sampling rates of 8, 11.025, 16, 22.05, 24, 32, 44.1, 48 & 96kHz in 6.1 mode & up to 192kHz in stereo mode.
-24-bit Analog-to-Digital conversion during recording in 8, 16 or 24-bit at sampling rates of 8, 11.025, 16, 22.05, 24, 32, 44.1, 48 & 96kHz.
-SPDIF output up to 24-bit at 48 or 96kHz.
-ASIO drivers for low latency (as low as 2ms) multi-track playback & recording at 16-bit/48kHz.
-Advanced Audio & 3D Audio Technology
-Dolby Digital audio decoding to 5.1 (digital or analog modes) or Dolby Digital EX decoding to 6.1 (analog mode only) speaker channels.
-Hardware acceleration of EAX & EAX Advanced HD for games.
-32-bit Professional Quality Effects Engine with support for real-time digital effects like reverb & chorus across any audio source.
-Wave-Table Synthesis & MIDI Features
-Creative Hardware synthesizer (2x16 Channels) with 64-voice polyphony featuring E-MU's patented 8-point interpolation technology for accurate sample reproduction.
-Creative Software synthesizer - multi timbral wave-table (16 Channels).
-SB1394/FireWire Connectivity
-IEEE 1394/FireWire/i-Link compatible interface with up to 400Mbps transfer rate.
-Sound Blaster Audigy On-Board Connectors
-Line level out (Front/ Rear/ Centre/ Subwoofer/Rear Centre).
-Digital Out for 5.1 support.
-Line in.
-2 Microphone in.
-2 SB1394/FireWire port.
-Analog/Digital CD Audio in.
-15-pin MIDI/Joystick port extension header.
-Internal SB1394/FireWire header to Sound Blaster Audigy 2 Internal Drive (Upgrade Option).
-AD_EXT extension header to the Sound Blaster Audigy 2 Internal Drive (Upgrade Option).
-Sound Blaster Audigy Audio Performance
-Signal-to-Noise Ratio (AES17, A-Weighted) Rated Output 2V:1V.
-Stereo Output = 106dB: 102dB.
-Front & Rear Channels = 106dB: 102dB.
-Centre, Subwoofer & Rear Centre =~90dB ~86dB.
-Total Harmonic Distortion + Noise at 1kHz (AES17) = 0.004% (1V, 2V Rated Output).
-Frequency Response = <10Hz to 46kHz (1V, 2V Rated Output).
-(+/-3dB, 24-bit/96kHz input)
Λεωνιδας 6972086325
Τιμη 35 ευρω
-Line in.
-2 Microphone in.
